Once I have created a survey and initial data has been collected within the survey and submitted. How or can you access those data points when your in the field and add existing information?
For example a survey was created to mark holes at a park. GPS point, Length and Width of the hole, a picture etc is collected for that existing hole.
Now returning to the site a month later I want to record any new holes, but will need to check if they have already been marked and then I would want to record if the hole size increased, so I may want to pull up a existing point collected and in the comments section say the new length and width.
Is this possible and if so how?
