Access fields that are in a survey's underlying feature service, but are not in the survey
629
03-08-2023 03:37 AM
CarlBeyerhelm1
I would like to access fields that are in a survey's underlying feature service, but are not in the survey.
For instance, get a value from the editor tracking fields CREATOR or EDITOR for the current record from the survey's underlying feature service.
Is this possible?
ZacharySutherby
Hello @CarlBeyerhelm1
Are you looking to access this information in the survey itself? Are you loading records from the Inbox?
Thank you,
Zach
CarlBeyerhelm1
Hi Zach.  Yes, within the survey itself.
For instance, when a record is retrieved for edit from the Inbox, I want to be able to make some questions read-only if the current logged-in username is not the same as the original CREATOR.  Essentially, this is setting up dynamic read-only questions dependent on the original CREATOR (posted the original record to AGOL), and the current editor.
Thank you.
