A survey within a survey: Is it possible to embed a separate survey into survey 123?
1521
10-10-2019 12:37 PM
Health_GISAdministrator
I am looking to embed a survey into another survey and have the survey taker go from one survey into another and then back to finish the first survey. Help? J
Tags (1)
by Anonymous User
Not applicable
Hi there,
This exact workflow is not currently supported in that the app and would be considered a feature enhancement that needs to be logged and implemented. There are some limitations that need to be resolved such as knowing which question you came from in the original survey and return to you to it when the second survey is finished. Iit is possible using the current URL scheme to launch a new survey via a URL. Have you tried this? You can find more information here: Integrate with other apps—Survey123 for ArcGIS | Documentation  or https://community.esri.com/groups/survey123/blog/2016/07/30/understanding-survey123s-custom-url-sche....
Whilst this is not the intended purpose of using URL schemes, as it is designed for launching Survey123 with a specific survey from a different app, I believe it can be used if it meets your workflow, but there are some limitations.
Regards,
Phil.
