1000 Places adding comma in Survey123 Website for Integer datatype
1033
02-10-2021 02:58 PM
vijaybadugu
I am getting 1000 places comma for integer datatype in data tab in survey123 for arcgis and when i try to  export the data to pdf the comma added to that integer field. How to get rid of this comma for integer field in Survey123 arcgis website. Please help.
MichaelKohn_PGE
Hi @vijaybadugu I am having a similar issue when my users are publishing Feature Reports from a Survey123 hosted feature layer where an 8 digit integer field displays commas. Hopefully an ESRI staff member or another GIS professional has an answer.
Is there a way to configure the syntax of a Feature Report template to not display the 1,000's place comma? I've tried configuring the pop-up to not display the 1,000's place commas which worked for the pop up but not the data table which the feature reports are generated from.
The image below shows the 8 digit number being displayed with commas when the desired out come would be displayed without commas.
