Adding autocomplete as an option for select_multiple questions would be very helpful, particularly for large lists where scrolling through all the options isn't feasible.
I agree. I have a species list that is 4000 records long. The autocomplete functionality works great for a select_one scenario but we need to be able to pick multiples in a given area.
Yes I agree also I have the same situation as above and this function would help greatly.
Thanks for this good idea, @RobertMcLeod ! My organization has the same need in a forestry context.
The aim is to pick out a list of parcels selected for forestry works.
I have a select_multiple on the forest parcels list ; users request an autocomplete behaviour to avoid loading the screen with potentially thousands of parcel names and tick boxes.
Many thanks, ESRI, for helping us help our users 🙂
I also have plant species list that is 4300 records long and it would greatly helpful to have an autocomplete or some type of search function available for select multiple questions.
Same here, we have incredibly long species lists in a multiple select form and autocomplete in a multiple select list would be incredibly helpful.
Agree. Autocomplete has been requested by our team. We have species list that are extremely long to have to scroll through.
Bump.
There is still interest in this feature ESRI!
It's 2024 and it still hasn't been implemented...
This is an extremely important functionality as in 2024 all modern digital forms support this.
Data needs and options only increase. In the construction industry we have 1000s of drawings and reference numbers that our engineers need to access quickly.
This prevents GIS adoption.
May I ask the community what alternatives they have looked at? I am thinking of a repeat function
I agree that this function would be very helpful! We have several long species list. I have come up with a work around by using repeat sections and then hidden line items that join all the species into 1 list by a formula in the calculation column. It creates a separate tab in the export but all observations are in 1 list and we are able to use the autocomplete function.
I'd like to see this added to the product as well!
This would be very helpful to my organization as well. Can ESRI staff comment on this feature at some point?
This is a great idea, but I wonder about the processing overhead. Maybe it would slow the app too much? Sometimes you can use cascading selects to partially achieve this effect, depending on your data structure.
If you're in the Early Adopter program, it appears this is available now in the Feb 2026 beta version of the Next Generation of Survey123.
Multiple choice appearances:
The expected public release of Next Gen Survey123 is by end of March 2026.
Thanks @ToddW_stl
Can we use this release yet? I couldn't find where.
@ThaissadeCastroAlmeidaCaino - unfortunately not yet. It sounds like a decision was made to release Next Gen Survey123 as new apps, which introduced some coordination issues with ArcGIS Online to get everything registered, and delayed the release until after the next ArcGIS Online release (middle/end of July - planned for right after the User Conference)
This would be a great addition. I have a question with over 25000 educational institutes to select multiple from. For now, I'll probably limit to one choice.
@Clubdebambos - have you joined or tried this functionality in the beta release available in the Early Adopter Community? You should be able to use whatever Survey123 project you set up in the EAC program after the final version is released in July, as there should only be minor changes and bug fixes between the current beta release candidate and the final version.
Hello!! I’d like to know if there are any updates. Can we use this release yet?
Are there any updates on the new release and this feature becoming available? We are now into September and it seems this has continued to slip behind??
Sign in to post, follow content, and more. New here? Register for free.
