register vertex position from built-in GPS when creatin a GEOSHAPE using the field app.
1395
08-24-2021 06:03 AM
Status: Already Offered
Labels (2)
CesarMendez
You only can create a Geoshape feature drawing in the screen (with your finger or using a point device), but it would be a great inprovement to create the vertex of the geoshape registering the positions of the GPS (built-in or external) in the same way ArcGis Collector does.
regards!
3 Comments
by Anonymous User
That feature already exists. If you are using survey123 connect to create the form, enter method=vertex in the body::esri:style column.
CesarMendez
Thanks Nicholas. It works fine.  👋 👋 👋 👋 👋 👋 👋 👋 👋 👋 👋 👋 👋 👋 👋 👋 👋 👋 👋
IsmaelChivite
From @Anonymous User : enter method=vertex in the body::esri:style column
Also described at:  https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-lines-and-polygons/ba-p/897415
