Please add a way to select all in a multiple choice using web designer
4019
11-04-2022 08:37 PM
Status: Needs Clarification
ChrisMiller_AK
I'm trying to avoid using Connect. Tring to keep is simple and easy to maintain between multiple staff. I've found that using the web designer is much easier to maintain. There needs to be a way in Web Designer to  create multiple choice question that allows you to select all.
2 Comments
ZhifangWang
ZhifangWang
Hi @ChrisMiller_AK ,
Can you please provide more details about the enhancement?
  • Do you want to set all choices in the question checked by default when opening the survey or add an option in the Survey123 web app so that the end user can easily check all choices by a single click?
  • Can you provide the same setting in Survey123 Connect if there is one?
