MODIFICATION OF DATABASE ORDER IF YOU CHANGE THE ORDER OF THE INTERVIEW IN SURVEY123
571
06-25-2020 05:15 AM
Status: Closed
AlvelalMonitoreo
New Contributor II
When you change the order of questions in a SURVEY123 questionnaire or add new questions in a certain order, this order can be maintained in the columns of the database.
That is, if you add new questions in the middle of the questionnaire, they do not go in the final columns of the database, but rather, the order you have given in the questionnaire is maintained in the data base.
It is normal, that over time new questions are added to the SURVEY123 questionnaire, and what currently happens is that you have a database (in the initial creation order), but not in the final creation questionnaire order and therefore, the database is disordered and is not very useful for analyzing the information.
1 Comment
JamesTedrick
Status changed to: Closed
Unfortunately, it is not possible to change the column order of the database.  You may want to ask for more flexibility to change the order of fields in displaying applications.  As an example, the pop-up configuration in the Map Viewer allows you to hide, show and re-order the fields displayed, in addition to creating customized displays of the field data.
