(Implemented) Survey123 Geoshape - Enable "method=vertex" on web browser for the Freehand Area tool - point and click vertices
3349
05-18-2022 11:09 AM
Status: Already Offered
Labels (3)
MōnoSimeone
We work with high resolution maps and need end-users to draw precise boundaries and angles in the Survery123 form Geoshape question. The majority of our users are submitting forms from their desktop with a mouse or pen to draw the shapes.
Survey123 by default uses the method=sketch, this setting makes the Freehand Area tool a point and drag action by the user, which behaves the same in the field app or browser. Changing the method to "vertex" changes the user action by requiring a point-and-click for each vertex -- but this is only enabled on the field app -- not the browser.
I am requesting Survey123 make the method=sketch available to web browser use.
4 Comments
DougBrowning
There is a setting for vertex already.  See here  https://doc.arcgis.com/en/survey123/desktop/create-surveys/geotracegeoshape.htm
MōnoSimeone
Thanks @DougBrowning. Is this functionality coming to the Web designer?
MōnoSimeone
Also @DougBrowning, I tested changing the default method value from "sketch" to "vertex", while this does allow the user to construct a shape vertex-by-vertex, it does so only on mobile devices; the functionality does not seem to be available for users entering a shape on a form in the web browser.
I am specifically seeking the vertex method to be available to users in the web browser.
IsmaelChivite
Status changed to 'Already offered'.
The following animation shows the use of the Survey123 vertex editing tools in a web browser:
Vertex editing tools in Survey123 web appVertex editing tools in Survey123 web app
To enable vertex editing:
  • In Survey123 Connect: For your geoshape or geotrace questions, set the value of the body::esri:style XLSForm column to method=vertex. More info in this help topic.
  • In Survey123 Designer: Enable the vertex editing tools as shown in animation below.
Enabling vertex editing in Survey123 web designerEnabling vertex editing in Survey123 web designer
