Add a return key to the Numbers appearance in Survey123
1517
09-04-2020 08:13 AM
Status: Implemented
DougBrowning
MVP Esteemed Contributor
Numbers appearance has no Enter/Return key
This means you have to tap somewhere on the form to commit it, then tap on the next field to get it to bring up the next numbers.  I know this was causing an issue with data not saved as well.  If you could just hit enter and it goes to the next field (like non numbers does) that would save the user a tap – so twice as fast.  This seems to work on text fields now so maybe it was just missed.
thanks
3 Comments
SkylerKasko
Great idea! It looks like this got added in version 3.12, though I haven't seen mention of it in the release notes.
DougBrowning
Yep I really bugged them about that one.
Next up tab order please.  Thanks team!
IsmaelChivite
