A new update to ArcGIS Survey123 is now available. The April 2022 release includes focused fixes, minor functional enhancements and Bulgarian language support. To learn what’s new in this and prior releases, you can also check our What’s new archive.
Some question types in XLSForm have additional parameters that allow you to control the style or behavior of questions in a survey. In some cases, these parameters complement the appearances that a question type supports. The new XLSForm parameters help topic describes all of them in detail.
Our next release is planned for May 2022.
XLSForm syntax
We hear again and again that you want to set the file name of photos using an XLSForm expression. We will share this very soon through the Early Adopter Program with the aim to make it available in May 2022.
In this upcoming update we want to expand the pulldata() function in XLSForm to help you more easily retrieve the survey title, full name of the signed-in user, version of Survey123 app used to submit data, and the operating system and device model that the app is running on. All of this is important if you want to understand where your data is coming from.
We will also continue working on the pulldata("@layer") functions we announced earlier .
Survey123 designer
Many of you create surveys and share your URLs in social media. In this upcoming update we want you to be able to customize the thumbnail and survey description that appear in the social media card. This will help you make your survey links more appealing. More appeal, more clicks.
If everything goes according to plan we will also make available, as a beta feature, CAPTCHA capabilities for your forms. Some of you have requested this feature to protect your public surveys from automated robot attacks.
We are also looking at adding new configuration options to the map question types so you can better constrain how people add data. For example, to improve the accuracy of data you may want to force users to zoom in to certain map zoom level before they can submit.
Survey123 field app
We are working with some of you to test alpha versions of new streaming tools to support field data collection workflows. We will have this work ready in beta in May. Our target is to make this available no later than June 2022.
We are also working to improve the audio recording capabilities of the field app. We want to reduce the size of the audio files created, allow you to record for longer, and give you options to control the output quality and codecs used.
Survey123 reports
Enhancements to the report engine to make PDF outputs more accessible are in the works and scheduled for release in May.
