Survey123 XLS Form Conversion Service
2862
10-18-2015 04:04 PM
HannahFerrier
1 2 2,862
Hello Survey123 Users!
over the past two weeks we have had a series of issues in our XLS Form conversion service. We want to say thanks to all of you that shared with us error reports, which helped us identify the problem.
A new version of Survey123 Connect for ArcGIS has been made available. You can download it from http://survey123.esri.com.  The latest build number is 1.1.19 and it will address the form conversion errors you observed.
The crux of the problem happen to be in some intermittent redirection issues in our esri.com servers. We have moved the conversion service now into the arcgis.com domain.  The 1.1.19 version of Connect now uses the service in the arcgis.com domain.   Alternatively, you can make the modifications in Connect yourself as explained here:
1. Open Survey123 Connect and select the 'Settings' icon
2. Change the URL from https://survey123.esri.com/api to https://survey123.arcgis.com/api
Again, changing the URL is not necessary if you download the latest version of Connect (1.1.19)
Thank you,
The Survey123 Team
2 Comments
RonKnepper
I downloaded the current version of Survey123 Connect.  When I create a new survey I now do not see the full heading options as prior?  They now stop after Column D, Hint?
RonKnepper
Got it, there is now a new form template and a blank version.  I didn't realize this, template has all the details.
