Survey123 Tricks of the Trade: Lines and Polygons
64130
55
09-26-2019 04:12 PM
IsmaelChivite
Esri Notable Contributor
16 55 64.1K
Starting with version 3.6, Survey123 supports working with line and polygon GIS features within your smart forms. There are many common scenarios for creating new, or working with existing, line and polygon GIS features in Survey123. For example:
  • To support a noxious weed control program, you need a form to report areas where certain chemicals are being applied. You will want your form to include a question for users to delineate the exact area (polygon) where treatment occurred.
  • You want to create a digital form following the SCAT methodology for assessing the impact of an oil spill along a shoreline. Your form must be able to let users highlight the segment (line) of the shoreline, or path, that was assessed.
  • Let's pretend you want to expedite the completion of ATC building inspection forms against an existing collection of building GIS features. In this case, you will want users to open an inspection form for the selected building (polygon) and let them complete all other details.
This blog describes how you can add support for line and polygon GIS features in your Survey123 smart forms using Survey123 Connect and XLSForm.  If you are not familiar with Survey123 Connect and XLSForm, please have a look at our Survey123 video tutorials, our XLSForm essentials—Survey123 for ArcGIS | ArcGIS help topic, or the Survey Customers to Gain Marketing Insight | Learn ArcGIS Learn lesson.
Support for configuring map questions in the Survey123 web designer to capture line and polygons is planned for a future release.
The Basics
The basics: geoshape and geotrace in Survey123 Connect
Hopefully by now you are familiar with the XLSForm geopoint question type. It allows you to bring a map question into your survey, so end users can define a point location of interest as part of your form. The geotrace and geoshape XLSForm question types will also be shown as a map within your form, allowing users to work with line and polygon shapes respectively.
To get started, I suggest you build a new test survey with Survey123 Connect and add the following questions:
typenamelabel
datetreatment_dateTreatment Date
geoshapetreatment_areaTreatment Area
If the geoshape question does not render correctly when previewing your survey, make sure you download and install the latest version of Survey123 Connect.  Geoshape and geotrace questions are only supported with version 3.6 and above.
Next, publish your survey to test your geoshape question within the Survey123 field app or web app. If using the field app, make sure you have version 3.6 or later installed on your device. You should be able to delineate a treatment area and submit. Using the Survey123 website Data tab, you will be able to look at your newly created features.
If you attempt to use geoshape or geotrace questions in forms authored prior to 3.6, keep in mind that the geoshape and geotrace options will not show in type column choice list. If you want to make these new question types appear in your old form, have a look at the https://community.esri.com/groups/survey123/blog/2019/09/15/survey123-tricks-of-the-trade-microsoft-... blog post.
The basics: geoshape and geotrace questions in the Survey123 apps
You can use geoshape and geotrace questions in both the Survey123 field app and web app. The user experience in the native app and web browser are very similar: A map is presented to the end user with tools to sketch or digitize the corresponding shape (line or polygon).
Here is what using a geoshape question looks like from a web browser (Survey123 web app):
And here is the experience for capturing a line in the Survey123 field app using a geotrace question:
You will notice that the map control shows an info bar describing the length and area of the shape digitized. The units in this info bar are set by your device locale. If your locale is set to the United States, imperial units will be used. Otherwise, metric units will be shown.
The basics: Looking at captured data in the Survey123 website
You can view and perform QA/QC operations on all Survey123 captured data using the Survey123 website. Through the Data tab you can visualize data captured through the geotrace and geoshape question types in a map and individual response views.
You can also bring your line and polygon data into your own custom Survey123 feature reports.
Beyond the basics
Adding multiple geo type questions in a survey
Values for geo type questions (geopoint, geoshape, geotrace) are stored in the SHAPE column of your surveys feature layer. The ArcGIS geodatabase model only allows for one single SHAPE (geometry) column per feature layer, so this restricts the number of geo questions you can add to a survey to one: either one geopoint, or one geoshape or one geotrace question. The only exception is when you add repeats to your survey: each of your repeats can also include its own geo question.
For example, with our SCAT survey, lets pretend you want to use a geotrace question to document the segment of shoreline surveyed and then you want to flag locations where severe oil damage has been found. You could create a survey as follows:
typenamelabel
datesurvey_dateSurvey Date
geotraceshoreline_surveyedShoreline segment surveyed
begin repeatsevere_damageSevere damage observations
geopointissue_locationLocation of damage
textissue_commentsComments
imageissue_photoPhoto
end repeat
Note that the survey includes two geo questions: one in the main body of the survey, and one inside a repeat. This is allowed because questions within the repeat will be stored in a separate (and related) layer.
Input Methods: vertex vs sketch
When using geoshape or geotrace questions, you can optionally define the input method of your map.That is, you can control which style of tools will be presented in the map to help users delineate a shape.  You can do this through the body::esri:style column in the survey XLSForm sheet.
The map supports to input methods:
  • sketch: Enables drawing tools in the map. This is meant to help users quickly draw, or sketch, a line or polygon in one single take.
  • vertex: This input method is more appropriate when you want users to digitize shapes more accurately. The vertex input method provides tools to add vertices one at at time by:
    • Tapping on the map.
    • Centering the map at a target location.
    • Getting the coordinates through the built-in or external GPS.
The vertex method also lets users switch between edit and navigation modes, update and delete existing vertices.
You will want to experience on your own each of these two input methods and decide what is best for your particular workflow. In some cases you want a simple and quick way for people to sketch a geometry. In others you want to give them more control, even if that implies some initial trial and error with the tools until they get familiar with them.
The following example shows how you can set the vertex input method using the body::esri:style column:
typenamelabelbody::esri:style
geoshapetreatment_areaTreatment Areamethod=vertex
XLSForm functions: Calculating perimeter, area and length.
Along with the geotrace and geoshape question types, we have also extended XLSForm support, so you can create expressions to work with these geometries. Two common functions we anticipate you using are area and length. Back to our noxious weed abatement scenario, the area function could be used to automatically compute the area treated.
typenamelabelcalculationbind::esri:fieldType
hiddentreatment_sqmCalculated Area in sqmarea(${treatment_area})esriFieldTypeDouble
Note that in the example above, the calculated area is stored in a hidden field. This is optional, as you could be using a decimal question type instead. You can use a hidden question to keep the output value without presenting it to the end user.  Hidden questions are mapped automatically to text questions in the geodatabase but since I want to store the area as a number, I added esriFieldTypeDouble value to the bind:esriFieldType XLSForm column.
The output of the distance and area functions is always in meters (or square meters), but you can easily apply conversions and rounding as needed.
round(area(${treatment_area}),2)Extracts the area in square meters of a geoshape and rounds the value to 2 decimals
distance(${treatment_area})Calculates the perimeter of a geoshape or the length of a geotrace. Output in meters.
distance(${shoreline_surveyed}) div 1000Gets the distance of a geotrace geomery in meters and divides by 1000 to get the distance in kilometers.
distance(${pipe_to_install}) * ${price_per_meter}Estimates the installation cost of a pipe.
The distance and area functions can also be used in other contexts. In the example below, we use the function to control if a particular question will be required or not. If the area treated is less than 100 square meters, then a justification text question will be shown, but it will not be compulsory. If the area is larger than 100 square meters, then a justification must be provided.
typenamelabelrequired
textjustificationJustificationarea(${treatment_area})>100
More on XLSForm functions:  repeats, sum and count.
With some creative thinking, there are some more advanced XLSForm techniques you could leverage when working with geotrace and geoshape questions. In the next example, a repeat is used to capture the exact location of electric poles. For each pole, type, observations and some GPS metadata for the pole location is collected. Using the sum function, a line feature representing the electric line joining all the poles is automatically generated.
begin repeatpolesPoles
geopointpole_locationPole Location
hiddenpole_haAccuracy (m)pulldata("@geopoint", ${location},"horizontalAccuracy")
select_one typespole_typePole Type
textpole_obsObservations
end repeat
geotracepole_lineElectric Linesum(${pole_location})
hiddenpole_count# Poles in Linecount(${pole_location})
While not included in the example above, it would make sense to set the geotrace question as readonly, to ensure that the electric line is truly following all the pole locations within the repeat. Otherwise the end user could open the map for the pole_line question and manually alter its geometry. Depending on your workflow, the desired behavior is up to you and can be configured either way.
Geotrace and geoshape in the Survey123 field app Inbox
So far, we have explored how to use the geotrace and geoshape questions to enter new line and polygon features. In some scenarios however you may want to simply reference existing line and polygon features and help drive data capture workflows within Survey123.
A classic example is that of building inspections. For example if you need to score a set of buildings to assess fire risk, or to evaluate damage after a hurricane or earthquake. Your intent in this scenario is not to create or update the polygon footprints. Instead, what you want is to update attributes in these existing buildings based on your own on-site assessment.
In this case, you will want to build your survey on top of the existing building (polygon) layer. The geoshape question will help you drive the whole user experience in the Survey123 field app, allowing the selection a building from the Inbox map and opening the assessment form for the selected building right away. When submitting your survey, the polygon shape of the building will remain untouched, but the attributes reflecting the assessment will change.
The next animation shows the whole workflow: 1) Bring features (polygons) into the Inbox, 2) Select a feature from the map to open its corresponding form, and 3) Submit changes to update the feature:
If this pattern interests you, keep in mind that the Survey123 field app Inbox is meant to work with a small number of features. When enabling the Inbox in Connect, I strongly recommend you set a filter to query and filter the features based on attributes (buildings pending inspection, or buildings assigned to the logged-in user, for example). From a practical perspective, with 3.6, you will not want to load more than 200 or 300 surveys in the Inbox. You will see some new performance improvements for the Inbox coming in future releases, but as of version 3.6, you will need to keep the number of records loading in the Inbox as low as possible.
Performance improvements to the Inbox are coming with version 3.7. As of 3.6, keep the number of records in the Inbox under a couple of hundred by applying spatial and attribute queries to the Inbox in Survey123 Connect.
For a more detailed description on the Inbox, check our Prepare for editing existing survey data—Survey123 for ArcGIS | ArcGIS help topic.
Including lines and polygons in your Feature Reports
Using Survey123 Feature Reports you can create high quality printable documents for any of your Survey123 records. Thehttps://community.esri.com/groups/survey123/blog/2019/07/23/understanding-survey123-feature-reports blog post describes in more detail how to use this feature. The Feature Report syntax has been extended to allow you to dynamically include in your report the perimeter and length and area properties of a survey record. For example:
  • ${segment_surveyed | getValue:"length":"meters":"geodesic"}
  • ${treatment_area} | getValue:"area":"hectares":"geodesic"}
The length property returns the length of a line and the perimeter of a polygon. The area property only applies to polygon features. The length unit options are feet, kilometers, meters, miles, nautical-miles and yards, for length. For area: acres, hectares, square-miles, square-kilometers, square-meters, square-feet and square-yards. The last property defines if you want to get the planar or geodesic measurement. If your data is in WGS 84 Web Mercator Auxiliary Sphere, which is going to be the case with Survey123 unless you set your own custom projection on the data, you should always use geodesic. If your data uses a local projection, typically planar will be the best option.
55 Comments
erica_poisson
I just tried out the "vertex" method, at some point in a future release, will it be possible to "stream" a feature through the "vertex" method? By this I mean in the way you can stream a feature while walking and using Collector.
Overall, this is very exciting, however the current method of adding a vertex at your location as you walk requires presence of mind to pause at corners and press the button. Also, I think that for people working in the woods, the ability to stream might be easier than having to keep the screen turned on so you can press the button to add a new vertex.
SkyeRodgers
This is so exciting. Thanks for all of the hard work Ismael Chivite! I noticed you said it is coming to web soon - and I can't wait for Australian schools to use this awesome feature. Is there an estimated time this feature will be available?
IsmaelChivite
Hi Erica. Adding support for streaming is something we can consider. I encourage you to submit an official Enhancement Request via Esri Technical Support or to post a new ArcGIS Idea.
One question on streaming: for your use case, would it be sufficient to keep streaming active until you either stop streaming in the map toolbar or close the map?  Or do you need to keep streaming while you work in other questions within your form.  In the last case, streaming would only stop if you go back to the map question to stop streaming or if you leave the form to save it as a draft or send it.
IsmaelChivite
Hi Skye Rodgers‌, kudos to the entire Survey123 team and the many Survey123 Early Adopters that have helped us get this out through extensive Beta testing. Ismael just happened to be the messenger here. We really hope you can get good use of this feature.  As soon as we have Lines/Polygons in Survey123 Web Designer available for Beta testing we will make a note in this GeoNet Group. If everything goes according to plan we should have Designer ready in early 2020 but timing can change.  Colleagues in Education from the US have also indicated that they want this feature in Designer. Really looking forward to have you all engaged so we can let the kids show us all what is possible with Survey123!
erica_poisson
Hi Ismael,
It would be more than sufficient, for my use case, to keep streaming active until I stopped streaming in the map toolbar. I'm picturing something similar to the way streaming is used within Collector. I don't foresee, for my particular workflow, the need to stream a feature and then continue answering other questions within my survey.
I will submit an Enhancement Request for this.
Thank you to you and the Survey123 team for all the amazing work on this!
Erica
SkyeRodgers
Yes all of the team are my heroes! Excellent, I would love to test it out. Having the feature available in Designer would make it easily accessible to all of our Survey123 loving students here and I can't wait to see the way it transforms their data collection! Kudos Sir!
ReedOjala-Barbour
New Contributor II
I agree that streaming would be very useful.  I will be sure to vote for it in ArcGIS Ideas.  Thanks for posting this question.
erica_poisson
Hi Reed,
I did not post an Idea, however I did log an official enhancement request through technical support. The enhancement request is - ENH-000125836.
Best,
Erica
ReedOjala-Barbour
New Contributor II
I added an ArcGIS idea here: https://community.esri.com/ideas/17374.
Reed
DerrickWestoby
Occasional Contributor III
Ismael Chivite‌ - Would you mind adding another section to your (awesome) blog post that describes how we can populate a geoshape using URL parameters (such as launching the survey form from a web map with taxlots)?
I had this working well in 3.5, but it now appears broken.  I'm going to go make a post in the EAC about this as well.
ESUser_1
Hi, When creating the geotrace and geoshape functions does it create a polygon shp file that can be exported?
JamesTedrick
Esri Esteemed Contributor
Geoshape will create polygon features; Geotrace will create line features.  There is an issue in exporting Survey123 data to shapefiles (BUG-000115279); that will be addressed later this year with the next ArcGIS Online & Survey123 updates.
BenVan_Kesteren1
Hey Ismael Chivite‌ et. al.
I am currently in the process of updating an old survey which was created a couple of years ago, to now use geoshape instead of geopoint, and I have hit a hurdle.
With geopoint I used to be able to calculate Lat/Long and also reverse geocode addresses. Can this be done with the newer geoshape or geotrace?
These are the existing fields that no longer work now I have a geoshape field instead of geopoint (and yes I have tried converting @geopoint to be @geoshape, this had no effect). These questions appear blank since updating.
pulldata("@geopoint",${location},"reversegeocode.location.x")
pulldata("@geopoint",${location},"reversegeocode.location.y")
pulldata("@geopoint",${location},"reversegeocode.address.Match_addr")
Any ideas if I can still calculate these coordinates and address using the new question type?
BrettStokes
Hi Ben,
Reverse geocoding works by comparing a Lat/Long pair to known address locations and returning the best candidates for a match so it requires a point location as the input. This is not going to work with a line or polygon (geotrace or geoshape) input without an intermediate step to extract the Lat/Long of one of the vertices.
We would need to add the ability to pull the Lat/Long coordinate pairs from the geotrace and geoshape geometry (eg pulldata@geotrace or pulldata@geoshape). This would be a valid enhancement request if you'd like to submit it via support.esri.com?
Depending on the complexity of your lines/polygons, you may be able to capture these using repeated geopoints (see the 'Geotrace and Geoshape' sample available in Survey123 Connect). This way you still have a geopoint to use as the input for a reverse geocoding operation.
Brett
BenVan_Kesteren1
Thanks heaps for that info Brett, that workaround may be what I need to keep moving forward.
I will look into it.
Just to confirm, you think I am best to request that enhancement via support.esri.com and not the ideas page?
BrettStokes
Hi Ben,
That's right submitting an enhancement request via support.esri.com will give you and official enhancement (ENH) number to track the progress. Cases like this where you're wanting to enhance existing functionality are best submitted to support.esri.com, where as ideas for completely new functionality are best submitted to the ideas page.
Brett
CPoynter
Hi Ismael Chivite,
Just wondering in your electric poles / transmission lines example, how could junctions be handled, where one pole might act as a point for two transmission line segments?
Regards,
Craig
by Anonymous User
Not applicable
Good afternoon,
I was curious if it is possible to upgrade a older XLS form to the newer version so that I can add the Geoshape function. Is there a work around so that I can add this function into the form or will I have to rebuild the entire form?
Gregg
by Anonymous User
Not applicable
I figured out a work around, thank you! Ended up just pasting values and transferring files over to new survey and it worked.
BrettStokes
Hi Gregg, you can just add the geoshape question to your old XLSForm. It will work if you're running a version of Survey123 / Connect that supports it (v3.6+).
by Anonymous User
Not applicable
Hi Ismael Chivite‌,
Is the sum function for generating lines from points supported in the Web App?
Cheers,
Chris
RyanMcKenna
New Contributor II
HiIsmael Chivite
I am working on a building inspection form and I would like the building shape to be populated in the Geoshape based on the building name selected from a drop down.  The form is setup to pull a number of fields from a CSV file and I can pull the vertex values to a text question with no issues. However when I try to pull the data directly to the geoshape question from the CSV or use a calculation to pull the data from the text question, I receive an error in Connect "java.lang.Number.Format.Exception: For input String..."
I know the vertex information is in the correct format as the building will show up if I paste the coordinates in the default field.
Am I missing a step that is needed to get the pull data function to work with geoshapes or is this not supported yet?
I know there is the option to launch from Collector but I would rather not require the teams to use another app if they don't need to.  I would consider using the Inbox method you outlined above but the inspectors need to collect photos and I don't see the repeat work around being a viable option for us.
Thanks
Ryan
IsmaelChivite
Hi Ryan McKenna‌ Can you send your CSV file to me?  ichivite@esri.com
AleksandraZietara
New Contributor III
Hello, where can I find settings to change the units of perimeter and area which are displayed on the survey form while drawing polygon? I see on your pictures that you use kilometers, but I get miles and acres as default and want to change it to kilometers. I have searched different places but I cannot find any option to change it. Survey123 form was created using the Web Designer.
by Anonymous User
Not applicable
Does this help?
by Anonymous User
Not applicable
Thank you very much.
DataOfficer
@Anonymous User I'm not sure that is correct as my device locale is the United Kingdom but does not show geotrace/geoshape measurements in metric.
This is logged as an enhancement: ENH-000128512 following case #02477998. Suggested workaround is to change the device language settings, however this is not feasible as would require every participant in our surveys to also change their device language.
by Anonymous User
Not applicable
Thanks @DataOfficer for investigating further and circling back to share the outcome.
TaylorSchyrbiak
New Contributor III
@RyanMcKenna - did you ever receive a solution to your above mentioned comment?
"I am working on a building inspection form and I would like the building shape to be populated in the Geoshape based on the building name selected from a drop down.  The form is setup to pull a number of fields from a CSV file and I can pull the vertex values to a text question with no issues. However when I try to pull the data directly to the geoshape question from the CSV or use a calculation to pull the data from the text question, I receive an error in Connect "java.lang.Number.Format.Exception: For input String..."
I know there is the option to launch from Collector but I would rather not require the teams to use another app if they don't need to.  I would consider using the Inbox method you outlined above but the inspectors need to collect photos and I don't see the repeat work around being a viable option for us."
I am experiencing the exact same problem...
maddiewithamap
Hi!
I am having an issue seeing respondent-input polygons in my Data section...can anyone provide input on this? My survey is a mix of text and geoshape/geopoint
I have just one geoshape to collect, set to method=vertex.
It lets me successfully draw in a polygon within the survey and submit successfully, but then I can't see anything in Data.
(I also have 4 geopoints and am collecting their x,y data successfully with pulldata('@geopoint...)
Thank you!
BrettStokes
Hi @maddiewithamap ,
Are you experiencing this problem owith the web app or with the field app? Is your polygon geometry (geoshape) within a repeat? Have you made sure you're looking at the correct tab in the 'Data' page of the website? Another thing to check is that you don't have the 'bing::esri:fieldType' set to 'null' for your geoshape question in the XLSForm. If you can send through your XLSForm I can help investigate further.
Brett
maddiewithamap
Thank you Brett, I had it as null. As soon as I removed that it worked perfectly.
Aurelija_RutaViluckyte
New Contributor III
@IsmaelChivite @JamesTedrick @BrettStokes I am experiencing problems with Survey123 registering polygons with geoshape question type.
What i'm working with: ArcGIS Enterprise 10.8 and ArcGIS Survey123 Connect v3.12 as well as ArcGIS Survey123 App v3.12
  • I have published a feature service (with ArcGIS Enterprise Server) from an Enterprise Database (.sde) (a polygon feature class with a related table (1:many), global ids, archiving enabled, sync enabled, non-versioned and all the requirements for such feature service to be possible to publish).
  • I have then created a Survey123 in the Connect app from this feature service. In the survey we want to draw polygons and collect data about these polygons.
  • Whilst no errors appear when publishing the survey, answering and sending the survey results, when trying to check the records in the Survey123 website on a map - they do not draw on the map.
  • It seems to me that this drawn polygon is somewhere lost along the way. All attributes are visible except the polygon itself. The web map is just blank. The Shape size and length is 0 in ArcMap (see screenshots below)
How can we fix this? I can't work like this any further and I don't understand what could be the root cause.
Mondi_GIS
"You will notice that the map control shows an info bar describing the length and area of the shape digitized. The units in this info bar are set by your device locale. If your locale is set to the United States, imperial units will be used. Otherwise, metric units will be shown."
Is there any way to work around this? In the South African regional settings, the decimal point separator keeps causing issues so we have to use the US location. This causes problems with our users who also need to have conflicting regional settings for SAP access, and also forces us to have acres as the unit for measure when we would really prefer square meters (hectares would be ideal).
IsmaelChivite
@Mondi_GIS: No options are available to control the display units via XLSForm. The app relies entirely on the OS settings. Alternatively, you could add a note question, right below the map control and have its label show the area in the units of your choice.
IsmaelChivite
@Aurelija_RutaViluckyteCan you see the polygons in the map when you load the layer in ArcGIS Desktop?
  • Can you see the polygons when you preview your feature layer in your web map? The first thing you want to check is if the polygons are being created correctly. It is suspicious that the area is set to 0.
  • What is the exact version of your database?
New Contributor III
@IsmaelChivite Hi Ismael. I already solved the issue by recreating everything from scratch, the only thing I changed when creating Feature Class from scratch is that Shape field > Allow Null > No (it was set to Yes previously, by default it seems). After this and all the identical setups, the polygons are drawing up on all maps and applications without problems.
But answers to your questions (for the record) are:
  • Polygons were not visible in ArcGIS Desktop.
  • Polygons were not visible in the webmap (Map Viewer) (actually, an error with exclamation mark was showing up "the features were not drawn completely")
  • I am not sure how to check the version of the database or what you mean by it. It is an enterprise database with archiving enabled, non-versioned datasets. The environment is all 10.8
/Aurelija
IsmaelChivite
@Aurelija_RutaViluckyteOK. Thanks for confirming. It is great to hear that things are working now.
Mondi_GIS
@IsmaelChivite we do have a calculated field but our field workers HATE having to exit the map drawing interface on the app to check the hectares calculation, and then go back in to edit the polygon.
Is there no hope for ESRI fixing the regional settings issues for non-US users? It's been years of struggling with these issues.
IsmaelChivite
@Mondi_GISPlease send a description of the non-US localization issues you are encountering to ichivite@esri.com   If at all possible include related Esri Technical Support cases you opened with Esri South Africa.
New Contributor III
@IsmaelChivite @BrettStokes Hello, I am trying to do a very similar set up for our Survey123 as described in here previously: Is there a solution for this?
Currently I'm using a CSV with city coordinates lat and lon to prepopulate the geopoint question.
However, we need applicants to draw polygons on Survey123 in each of their selected city locations and we need the map to zoom-in based on their selection.
So I can't figure out how to use the CSV coordinates to prepopulate the geoshape question?
Is there a special way how to create a polygon coordinate string from the point coordinates, for example?
Thanks a lot in advance! You can also contact me at auvu@cowi.com
KylieRyan
Hi!
The building example is almost identical to what I am trying to do with parcels of land for our weed inspections - except that the property layer is a read-only layer that I cannot update / edit. A copy cannot be made, as property ownerships are changing daily and need to accurately reflect this when the inspection occurs.
Is there somewhere I can find a step-by-step way to manage this?
Any help is greatly appreciated!!!!!
NaomiBegg
I've built a survey where the user describes something and is then asked if they want to map the feature as a point, line or polygon and then it has a repeat built in which brings up the relevant shape for them to draw.   This is great as the features they are describing can come in all sorts of shapes and sizes (i.e. a point of interest, a road, a series of roads or township ...).
However the problem is ... that I now can't figure out how to show this on a map!
The shape features have a parent GID which in desktop software can be joined, but I need to display the information as it comes in online as a combination of storymaps and dashboards.  I want to be able to have the symbol based on a type selected in the description before the shape repeat and the popup to be filled with the fields from the description.
Is there any way that I can make this work?!
FedericoRiet_Sapriza
New Contributor III
Hi @IsmaelChivite
great function, I have a Survey form in which I would like include pre determined polygons with the geoshape function  (parcels from several farms) in which data will be collected for each parcel.
So in short, if the fieldworker selects Parcel 1, I would like to parcel 1 (polygon) appear on the map, and then the data collected will be associated with that parcel 1. can I do this with select one function?
Is this possible?
Cheers,
Federico
OlaniyanOlakunle1
Can someone kindly assist me, my polygons either shift or expand a sketching/plotting using the vertex method in survey 123.
What could be the cause/responsible for this & what can I do to resolve this problem going forward. Thank you in anticipation
by Anonymous User
Not applicable
@OlaniyanOlakunle1 Can you please provide more information about what version of the field app you are using, what device make and model, and is this new issue you see, or did it occur in previous versions? Also any other information about your survey, are you using a geotrace or geoshape question type, and details about the basemap in use etc?
Regards,
Phil.
ChrisRoberts2
Is it possible to caluclate the geodesic area/length of a geoshape/geotrace question within Survey123 ie a calculation in survey123 Connect?
SIG-EscutismoCNE
New Contributor II
Hello @IsmaelChivite ,
is it possible to place the map at a distance of two points in Survey123 Connect, as arcgis online does?
Best regards,
r_povilaityte
New Contributor II
I stumbled upon this thread, while looking how to pass geometry to geotrace question from a street layer from my portal. I'm using pulldata("@layer") function to get street geometry and my goal is to draw it on a map, so that the user can create a line segment by simply selecting a street from select_one question or in other cases, modify that line (for example, only part of the street needs to be cleaned).
I would receive "java.lang.Number.Format.Exception: For input String..." error as some of you before, and finally I have found a solution! Maybe some of you might find it usefull 🙂
If you are planning to use your survey on field app:
Although, in documentation it says you have to pass a string with this sort of format "-37.842156723211474 144.95942945338243; -37.83554486071995 144.9726235713864; -37.85681405373047 144.98240735651922; -37.85954045531896 144.97715349053766", it does not work if you pass it from javascript function (in my case), from csv, etc.
What does seem to work, is passing a string in this format:
"type":"point",
"x":23.327310000000077,
"y":55.933080000000075,
"spatialReference":{"wkid":4326}
"type":"point",
"x":23.317310000000077,
In this case, I would:
1. use pulldata("@layer") function, with getRecord option (or maybe getValue with "geometry.paths" can be used), to get the street geometry
2. then I would parse the JSON in custom JS function and return the dictionary provided above, then calculate geotrace or geoshape from it.
If you are planning to use your survey on web app (little bit more tricky, but still possible):
Important note: web app doesn't support calculations like mentioned above and understands JSON differently (in web app, for JS function to work, I need to use JSON.parse function, while in field app - I don't).
So in this case, I would:
1. create a related table for temp coordinate pairs (because I don't think you can put a type null on whole repeat, right?) and this table should have x, y, position (using position(..) calculation) and concatenated coordinates fields
2. use pulldata("@layer") function, with getRecord option (or maybe getValue with "geometry.paths" can be used), to get the street geometry
3. then I would parse the JSON in custom JS function and return the count of coordinate pairs and set this number as my repeat count
4. for each x and y I would use another JS function to get specific coordinates from the array from the 2 step. Position is needed to know which pair of coordinates to return (-1 🙂 )
5. then, you should concat(number(${x}), " ", number(${y}) in your concatenated coordinates field. This step probably the most important one, which made us all struggle so much :D, because in all other cases, if you pass full coordinate pairs in a single string, but from calculation (pulldata from csv, JS, etc.), it seems that Connect does not understand, that those coordinates are numbers (just my speculation 🙂 ).
6. finally, on a geotrace or geoshape field, use calculation join(${coordinate_pairs, ";").
If you don't see your line or polygon, you might want to add additional question, that would say "Calculate" or whatever, and the last step would run only after "Calculate" is selected.
I tried this with street that had 74 coordinate pairs, it created all the pairs and the line shape in seconds. 🙂
Czapiga_Jason
New Contributor II
@IsmaelChivite
Thank you for another informative blog post!
I've set up my survey with geoshape question that includes a repeat and a nested repeat
geoshape
     repeat table
               repeat table
I intend users to use the inbox as you describe in the section above: Geotrace and geoshape in the Survey123 field app Inbox.
Everything seems to be working as expected except that the nested repeat (table related to the table) will not allow additions when queried from the inbox.  The first repeat does (that is related to the shape), but the repeat within the repeat only loads the data and there is no "+" on the record selector to add records to that nested repeat. It's acting as if that child table has a one-one relationship with the parent table.  I downloaded the service to a GDB just to check that and it is set up properly with a one-many relationship between those tables.  Any ideas are appreciated as this is what I need to work for my users.
