How to create buttons to invoke survey123 from workforce or collector
3534
05-14-2018 11:35 AM
RogerMesen-Delgado
There is a way to invoke #Survey123 with the fields fill. With the URL. if you want to know more about how to configure the URL is better to check the following link (click here). In the blog Ismael Chivite  explain deeply how to use the url.
This blog is more about how to transform the link in a button to show a better graphic interface to the user.
Basically when you have the link with the url of the form and you are setting the pop-up you can configure a "kind of button", with the following #html code.
<font size="5">
<a href="arcgis-survey123://?itemID=xxxxxxxxxxxxxxxxxxxx" style="display: inline-block; outline: none; cursor: pointer; text-align: center; font-style: normal; font-variant: normal; font-weight: normal; font-stretch: normal; line-height: 100%; font-family: Arial, Helvetica, sans-serif; padding: 0.5em 0.8em 0.55em; text-shadow: rgba(0, 0, 0, 0.3) 0px 1px 1px; border-radius: 0.5em; box-shadow: rgba(0, 0, 0, 0.2) 0px 1px 2px; text-decoration: none; color: rgb(255, 255, 255) !important; background: rgb(17, 127, 170) !important;">Orden de Trabajo</a> <br /><div style="text-align: center;"> </div>
</font>
this code shows up the following button in collector or workforce. Depending of the pop up that you set.
As you can see is a better interface that a link for the user. I you need more information just let me know in the comments.
4 Comments
AprilChipman
Occasional Contributor III
Where would this button show up in Workforce and Collector?
JamesTedrick
Esri Esteemed Contributor
Hi April,
Workforce already has an integration with Survey123 built into the app - see Esri Apps for Field Work, Work Together for more information.  In the case of Collector, you would substitute the link in the pop-up with the formatting.
JamesTedrick
Hi Roger,
Great idea - that certainly makes the visual much more accessible!
ColemanShepard
Hello!
Thank you for posting the code for the button! I'm running into issues regarding formatting across Esri applications. When I configure the button in a web application the button looks fine in the Collector application (See Image 1), but all the styling does not seem to carry over to the Workforce or Explorer applications (See Image 2). Has anyone experienced similar problems and know a work-around?
The images are from a IOS device.
Image 1. Button viewed in Esri's Collector application
Image 2. Button viewed in Esri's Workforce and Explorer applications
About the Author
Hi, I'm a GIS Specialist, Anthropologist is my base career and finishing my Msc in Geography. I like to help people to solve their issues with GIS. I've been working with different industries, like local governments and private companies. I also writing my thesis about risk and hazards. If I can help, let me know.
