Dates and Time in Survey123
151949
120
04-17-2016 10:00 AM
IsmaelChivite
Esri Notable Contributor
28 120 151K
[Updated June 16, 2020]
[Updated September 18, 2023]
[Updated October 25, 2023]
Note: In October 2023, ArcGIS Online introduced new date and time field types. We will add support for these new fields in Survey123 in 2024.  This article will be updated accordingly once we have support for the new field types. Until then, everything below applies only to esriFieldTypeDate.
In this blog post I will describe how you can work with dates and time in Survey123 with XLSForm. I will also cover important concepts for you to understand how dates and time are modeled in ArcGIS.
Before we start
To best follow instructions and concepts in this blog, I suggest you open the Dates & Time survey sample in Survey123 Connect. If you have a first look at this sample survey, it will much easier for you to follow content in the blog.
  1. Open Survey123 Connect
  2. Tap on New Survey
  3. Select the Samples category
  4. Scroll until you see the Dates & Time survey sample or use the search function.
  5. Create a new survey from this sample
Create new survey sample in survey123 Connect
Next, spend some time going over the survey. I suggest you explore it first in Connect and you also bring it into your phone or a web browser to see what it feels like. The structure of the blog pretty much follows the sample survey.
Basic Types and Appearances
The Basic Types and Appearances section of the survey sample explores the different ways in which a date or time question can be presented to the end user. Combinations of the question type and its corresponding appearances, will help you control the best user input style that fits the needs of your workflow.
The first question in this survey is of type date and it uses no appearance. A calendar control is shown for users to pick a date.  Note that the question shows the current date by default. This is accomplished by setting the default column in the XLSForm to today().
The following 3 questions illustrate the use of appearances: Year, Month-Year and Week-Number.
  • Week-Number is the most exotic. Week numbers are often used in government and business for fiscal years and timekeeping. With this appearance, the calendar widgets will let the user pick a date and display the week number in the form.  You will also see the week numbers on the side as you select the date. The week numbers are calculated following the ISO-8601 standard.
  • The Year and Year-Month appearances are handy when you simply want to present the user with a choice to pick a year, or a year-month.
As you exercise the calendar control, it may not be obvious, but you can actually tap and hold the arrows to quickly navigate back and forth in time.
Survey123
  • The DateTime and Time questions are shown at the end of this first section. Note that the questions automatically show the current date and time. This is accomplished by adding he now() function into the default column.
Understanding Dates and Time in ArcGIS
The Date, DateTime and Time types of questions as well as their corresponding XLSForm appearances, help you control the user experience that you want to present to the end-user capturing the data, but it is also important to understand how that date will be stored in ArcGIS.
User input to the Date and DateTime questions will be persisted in ArcGIS in a field of type Date (esriFieldTypeDate).  Despite the name of this field type, ArcGIS does not store just dates in Date fields: ArcGIS date values always include time as well. Hence, there is a perfect match between DateTime questions in Survey123 and ArcGIS date fields, but when it comes to date questions in Survey123, you need to understand that actually the time will also be stored.   But what time? Well, it depends:
  • The time will be noon (12:00PM) if the user has manually selected a date, or if you set the date using the today() function.
  • The time will vary if you set the date using the now() function. Now captures the current time, even if your date question does not show the time to the user in the form.
The screenshot below shows how you can configure a date field in your layer to display time. Note that in the Map Viewer, I had to open first the Fields dialog, then click on the date field and finally turn on the "Show time" option.   Once you do this, your popups will display time information!
Time values in Date and DateTime questions  are always persisted as Coordinated Universal Time (UTC). This is important when you have people working in different time zones. ArcGIS clients will translate the stored UTC values into your local time zone. The only exception is ArcGIS Pro. ArcGIS Pro will show the time in UTC (unless configured to do otherwise).
So far, I described how date and datetime questions behave. Lets talk next about Time questions, because they are special. For Time questions, Survey123 does not use the ArcGIS date type (which we know now that actually stores date and time). Survey123 time questions store values as a string. We did it this way, because otherwise you would get dates as well, and this could be confusing: Say you want to capture the time when a store opens.... you would not want the date in there...  Now, because time is stored as a string, there is no information regarding the time zone in it. As such, you need to keep in mind that there will be no time zone conversion.  Later in the survey, we will explore how to capture times differently.
Date and DateTime questions store values as date objects including time. Time questions store values as text.
Formatting Dates
All graphical controls in the Survey123 apps will honor your locale regional settings. For example, if your browser or smartphone's locale is set to Spanish, then dates will be formatted the Spanish way (which is the correct one, by the way... just kidding).  In the next screenshot I show what the calendar control will look like in a phone set with United States vs Spain regional settings. Note that when using the Spain regional settings, the day goes first, then the month and then the year, versus the US version where the month goes first then the day and then the year.
Survey123 Dates English Spanish
Additionally the format-date and format-date-time function allow you to convert date objects into strings.
In the following example, we  use the wsdatetime question to capture the date and time at which a water sample was taken. The wstime question calculate will be hidden from the end-user and is used to extract the time entered and persist it as a string in military format.  Note that the output of the wsdatetimequestion is stored in ArcGIS as a date object in UTC, versus the wstime which will be stored as a string using local time in your device.
type name label calculation
dateTimewsdatetimeSample Date/Time
calculatewstimeTimeformat-date(${wsdatetime},'%H:%M')
The qualifiers in the format-date function are as follows:
%Y4 digit year
%y2 digit year
%m0-padded  month
%nnumeric month
%bmonth name abbreviated
%d0-padded day of month
%eday of month
%H0-padded hour (24-hr time)
%hhour (24-hr time)
%M0-padded minute
%S0-padded second
%30-padded millisecond ticks (000-999)
%aThree letter short text day
Date and Date-Time Defaults
Survey123 accepts three possible values in the XLSForm default column:
  • today() This function returns the current date in your device. Typically you apply this function to questions of type date. The time part of this date will always by noon (12:00pm).
  • now()  This function returns the current time in your device. Typically you apply this function to questions of type datetime.
  • Finally, you can also apply a fixed date in ISO 8601 notation. For example: 2020-06-23T00:00:00-07:00.
    • 2020 for the year. Always 4 numbers.
    • 06 for the month. Always 2 numbers
    • 23 for the day. Always 2 numbers
    • T is simply a separator, for time. Always T.
    • 00 for the hour. Always 2 numbers
    • 00 for the minutes. Always 2 numbers
    • 00 for the seconds. Always 2 numbers
    • -07:00 is the UTC offset, which in this case is minus 7 hours.
Technically, you could also apply default value using Unix epoch notation (in milliseconds), but this would only work in the Survey123 field app. For consistency across the field and web apps, it is best to use ISO 8601 notation.
Constraints and Calculations
This section of the sample survey will be useful to understand how you use formulas with dates and date-times, so you can validate user input, as well as pre-compute date values. The questions in the survey are self-explanatory, The best is that you have a look at the XLSFile to better understand how things are done.
  • Constraints: A common constraint you will want to enforce is one that ensures a date is in the past or the future. That is pretty straight-forward: .> now() will ensure the user input is in the future for example. If you want to reference another question in the survey, you can use something like this: ${birthdate}<today(). This will ensure that the birthday question has a value in the past.
In constraints you may be asked to ensure a value is always newer and older than a fixed date. The date function is very useful in these cases. For example, you can set a constraint such as . > date('2006-01-01') or ${manufacture_date} > date('2006-01-01').
If you need to work with time constraints, simply add the time component to the date() function using the ISO 8601 notation.
  • Calculations: Calculations are easy too, as long as you understand that dates in the Survey123 app are encoded as numbers. When users pick a date or a date-time in the survey, all values will be presented in a human friendly way, but internally the application handles them as numbers that represent the total time elapsed since 1970. A positive number represents a date after 1970 and a negative number a date in the past.  As you can imagine those are pretty big numbers, but the math is simple once you understand how time is expressed. There are basically two formats for the elapsed time:
  • Unix epoch is the elapsed time since 1970 expressed in milliseconds.
  • Decimal date or French Revolutionary Time is the elapsed time since  1970 expressed in decimal days. That is, one day is 1.0, an hour is 1/24, a minute is 1/24/60, etc.   To learn more  about Decimal Time have a look at this 'How the French made a 10-hour day' article. You will love it!
 UNIX EPOCHDECIMAL DATE
2 weeks into the futurenow() + 14*24*60*60*1000date(decimal-date-time(now()) +  14)
Calculate age from birthdayint((today() - ${birth_date}) div (1000*24*60*60* 365.25))
int((decimal-date-time(today()) - decimal-date-time(${birth_date})) div 365.25)
Minutes spent for lunchint(${LunchEnd} - ${LunchStart}) div (1000*60)
int((decimal-date-time(${lunchends}) - decimal-date-time(${lunchstarts})) * 24*60)
15 minutes from nownow() + 15*60*1000
date-time(decimal-date-time(now()) +  0.0104166675)
0.0104166675 is equal to  (1 (day) / 24 (hours) / 60 (minutes) ) times 15 (minutes).
I recommend you work with decimal date format, because then your XLSForm expressions will work both in the field and web apps. The Survey123 web app ONLY supports decimal time.
If you plan to use date expressions in the web app, use the decimal-date-time function.
If you ever need to populate a Survey123 date or dateTime question using a UNIX epoch number, you can use an expression like this:
typenamelabelcalculation
textepochEpoch (milliseconds)
dateTimemydateThe Datedate-time(int(${epoch}) div 86400000)
Calculates and Relevants
This section in the sample survey is very similar to the previous one, but shows some other techniques that may be handy. For example, note how a calculate question is used to get the Lunch time computed, and then that value is used in other expressions throughout the survey.   A calculate is a type of question that will let you keep the result of a calculation without having to show it to the user in the survey.
You will remember that questions of type time are ultimately stored as strings in ArcGIS, however, as far as calculations go, you will treat them as numbers. That is actually pretty handy because otherwise, you would not be able to do much with them!
Other ways to capture Time
The last section in the sample survey shows other techniques to capture time.
  • The 'Time from a list' example should not come as a surprise. A select_one type of question with minimal appearance is a nice way to present a list of hours to choose from.
  • Then there are some other examples illustrating how to use regular expressions in constraints as well as input masks.  I will go into the details here, so nothing is missed.
    • First, an example to capture military type with a period. For example: 11:35.  Note the use of an input mask here. The input mask automatically adds the period (:), so the user does not have to worry about that. The value of the input mask is 99:99 meaning that we expect to digits followed by a period and two more digits. You will see that the constraint column checks to make sure that the hours do not go beyond 23 and the minutes do not go beyond 59.  Note: input masks are NOT supported in the Survey123 web app.
    • In the second example, we want to capture military time, but without the period. For example: 1135. In this case, I want to highlight a couple of things. First, note that I am not using an input mask like before. It is not needed, because we can set the type of question as integer (to ensure that only numbers can be typed) and also set the the maximum length of the field to 4. This is done through the bind::esri:fieldLength column. This will do two things: will ensure that only integers with 4 digits can be entered into the Feature Service, and most importantly, will limit the user input in the Survey, to 4 numbers.  I still added a regular expression in the constraint to ensure that proper values within the 24 hour day are entered.
    • In the third example, I want to capture military time including the time zone. For example 1445Z. Z is the time zone (ZULU, which represents UTC). In 1445G, G is for Golf and represents UTC + 7.  That would be 1445 Golf Time. How awesome is that! More details on this crazy business with Time Zone Abbreviations here. Again in this case I added a mask and complemented it with a regular expression in the Constraint.
If you are not familiar with input masks in Survey123 I recommend you have a look at the Esri custom columns help topic. Regular expressions are tricky to put together, but you can find loads of samples in the web.
Start and End
So far, we have been looking at date and time questions that were visible in the survey. It is for this reason that we cared about the user experience (types of questions, defaults and appearances) as well as the validation of inputs (input masks, constraints).  Now, in Survey123 there are a couple of handy question types that will capture time without the end user knowing. These questions are start and end.  When added to your survey, like in the Sample you are looking at, they will not show in the survey to the end-user, but they will populate data in the Feature Service, that you can see from the survey123 web site or a web map.
Start and end will capture the exact date and time at which the survey was initially opened by the end user, and flagged as done. For you to see how this works, the best is that you load the survey in your phone, complete a couple of surveys and submit the data.
The start and end values are useful if you want to understand how much time people in the field take to complete surveys. To calculate the duration of the survey, you will need to download the data in FileGeodatabase or Shapefile format and calculate a new field with ArcGIS for Desktop. This ArcWatch article describes how you can calculate the duration between two date fields.
On top of start and end, which are optional, you will always get the Creation and Last Edit date and time for every row you add from Survey123 for ArcGIS. It is important to highlight here that the Creation and Last Edit columns are handled through ArcGIS Editor Tracking. The help has a good topic on Editor Tracking in case you are not familiar with it. Do not worry about  enabling Editor Tracking in Survey123, because it is always enabled by default. This feature looks at the time when edits are made in the Feature Service not when the data is necessarily being captured or changed in the field. For example, if someone is working in the field while disconnected from the network, the start and end field will truly reflect the time when the user is working on the survey. The Creation and Edit Times will reflect the time when the data was actually submitted: May be immediately after data capture, or may be a couple days later while back in the office.
This was a long post, but I hope you find it useful.
120 Comments
RescateCaracas
New Explorer
Hola
How we can find the name of the day of the week in a date. Thanks
KDHEITGIS
I want a regex /constraint to show times in 30 minute increments only for the time entry field.
How do I go about that?
Thanks!
ahargreaves_FW
USFSRegion09
New Explorer
Why do my dates continually store time as well.  This is really annoying, and the advice the ESRI Custom Columns  https://doc.arcgis.com/en/survey123/desktop/create-surveys/esricustomcolumns site state To control the field type, provide one of the following values in the bind::esri:fieldType column:
  • esriFieldTypeDateOnly
This is not an option in the 'Field types' tab, so if you add it, and publish the survey with esriFieldTypeDateOnly as one of the bind::esri:fieldType fields it gives you an error when you try to capture that data and submit a survey.  Can you please explain what you are trying to do here?
RobertAnderson3
MVP Regular Contributor
@USFSRegion09 What version of Survey123 Connect are you using? The DateOnly and TimeOnly field types are fairly new, I think it was just added in the most recent release in February so you may need to update the Connect app for it to allow you to use them.
DerrickStark
@IsmaelChivite I have a question that only requires a month/date option. It can't include the year because this is a legal document.
Is this type of format possible using the date type or is it better off just using a text type?
abureaux
MVP Frequent Contributor
@DerrickStarkA "Date" question includes year by default.
In your case, I'd say there are two alternatives:
  1. Use two separate Select_one questions. One with months, and one with days.
  2. Use a single text question with an input mask. E.g., An input mask of 99/99;# would result in something like 05/23... While this is an option, I'd recommend going with option #1 above. It will be much cleaner and not prone to errors (you mentioned this is a legal doc, so you will want to minimize chances for user error).
ChrisHiguera
Occasional Explorer
Hi! I'm trying to convert the date format from dd/mm/YYYY to mm/dd/YYYY but this format didn't change, I'm using the following structure:
typenamelabeldefaultcalculation
dateTimedatetodayThis is the current datenow()
calculatedatecalcModified Date format-date(${datetoday},'%m/%d/%Y')
Could someone explain me where is the missing structure or why this didn't convert?
abureaux
@ChrisHiguera
Your calculate is fine as is (see below).
Two things:
  1. Calculates don't need a a "Label", so you can delete that label if you'd like.
  2. If you are expecting the dateTime question's format to change, it won't it is stuck as it appears. Your modified date/time is your calculate. You can reference that calculate somewhere else in your survey or in a Feature Report and it will appear as it should. If you would like to inspect the result of the calculate yourself, just change it from a "calculate" to a "text".
RachelS
@IsmaelChivite @JamesTedrick
The Start and End date and time is exactly what I need, but please explain where I find it.
I've downloaded the Date and Time form and submitted a survey but I can't see any fields with the date and time of when I opened the survey and when I submitted the survey.
I can't see it in the xls either! There's a lunchstarts and lunchends but that can't be it as the user inputs to those fields. I take it the Start and End fields are hidden so the end user doesn't see them but I can't see them anywhere.
DionysiosKerasidis1
Hi everyone
i dont seem to be able to set a constraint on 'time' type field. i ahev tried multiple ways but it seems only datetime can apply those. For example i have start and end time and i simply need the end time to be after start time.
i guess this is a limitation?
NateHollenbeck
Looking for some help with a date field.
I am using Survey 123 connect and I have a date field that captures today's date using today() in the default section. Within the survey itself it populates today's date just fine, but when the survey is submitted it captures yesterday's date in the data. Also, when generating a report, I am using that date field in the report, and it populates the report with a date 2 days prior from today's date.
Hoping to get a solution soon. TIA
PatIampietro
I have a calculation for minutes elapsed between two Time fields, begin_flight and end_flight, and I'm using decimal-date-time for my calculation to ensure it will work in both the Survey 123 and the web apps:
round((int((decimal-date-time(${end_flight}) - decimal-date-time(${begin_flight})) * 24*60)+0.5),0)
I'm rounding to avoid zeros.
However, the calculation is not happening in the web app, only in Survey 123.
Is this because the input fields must be dateTime instead of Time? I'd rather not use dateTime as I don't think there is a way to hide the date and only display time in the question on the form, and I'm trying to streamline the user experience. The date will never change between begin and end.
How do I get this calculation to work in both clients?
abureaux
@PatIampietro "time" fields aren't actually time fields. Use a "DateTime" field to do true time calculations.
PatIampietro
Thank you @abureaux , I wondered if that might be it. I will try switching the input types to "dateTime" to see if the calculation works in the web app..
Do you know of a way to hide the date portion of the question on the survey form? I really don't want to force my users to click through setting the date twice for no reason....
Thanks again for any advice!
MichaelBruening
@PatIampietro this article might be able to help you with the formatting, but please keep in mind I do not use the web application much.
PatIampietro
@MichaelBruening thank you, but you've referred me to the very blog post on which we are both commenting.
This thread is where I learned the decimal time difference formula, but does not address whether the Date portion of a dateTime question can be hidden. @BetsyDuarte asked (in 2019) whether that was possible, and an anonymous user answered that is is not, but I was hoping for more current and authoritative resolution to the question.
MichaelBruening
I see what you are referring to now and my apologies.
Is there a means to set the calculation of "today()" within both fields to set the date automatically. Then you could ask the user to edit the time portion of each question using a note or something.
That way the date is set to the day they fill out the form, they can still edit the time, and then your calculation will hold true. Not exactly what you want, but it will definitely get you the result you want.
PatIampietro
Thank you again @MichaelBruening, no worries, circular references happen!
The Date portion of the DateTime question does autopopulate, but it takes up space and is redundant in this case, and invites the user to tap/click. I designed the form with a single Date question elsewhere, which is much more efficient. BTW I think if one uses "today()", it automatically sets the Time part of DateTime to 1200 PM, which is actually counterproductive in my case because I want to default to current time, also for the sake of efficiency. I think "now()" is the better option in this case.
MichaelBruening
Sounds like you might have a form that will only populate the date/time field based on exposing the questions, but I am not sure.
Seems like you could have saved some time with a hidden field or two that captures the date and then just used two "time" only entry fields and used your calculation. I am not sure, but we can both agree that there is no means of changing the display of the Date/Time question.
