ArcGIS Survey123 December 14 Quick Fix Release
1366
12-14-2022 02:54 PM
IsmaelChivite
Esri Notable Contributor
4 0 1,366
The ArcGIS Survey123 December 14 Quick Fix Release builds on top of the December Release 2022. It addresses the following software defects:
Survey123 field app
You need to download the latest version of the Survey123 app into your device for this fix to take effect. The app build number should be 3.16.114 or above.
Survey123 website and web app
The fixes and enhancement above have been applied to the Survey123 web app and website. You do not need to do anything to benefit from them, except if you have installed the Survey123 website locally. If this is the case, these fixes will be included in the next update to the Survey123 website installer.
You can find what's new in this and previous releases at: https://doc.arcgis.com/en/survey123/faq/whatsnewsurvey123.htm
