Street map premium add Routing_ND
1922
07-09-2021 04:56 AM
VictorTey
Hi, when I try to add Routing_ND, I get a Access denied error :). am I doing something wrong?
megan_r
Hello Victor,
That error usually indicates you need an additional license to access the data. When using StreetMap Premium in ArcGIS Pro, there are two licenses that authorize different features: a data license (file ending in .sdlic) and the extension. Here is a little matrix that explains the licensing requirements of StreetMap Premium features: https://doc.arcgis.com/en/streetmap-premium/get-started/license-reqs.htm
If you trying to use the Routing_ND in the Standard SMP file geodatabase, you will need to add a data license (sdlic) that corresponds to the StreetMap Premium release you are using.
If you are Custom Roads SMP file geodatabase for routing, you will need to enable the StreetMap Premium extension as per: https://pro.arcgis.com/en/pro-app/latest/help/data/streetmap-premium/get-started-with-streetmap-prem...
Best,
Megan
megan_r
Hello Victor,
Best,
Megan
George_Thompson
Esri Notable Contributor
You may need to make sure that correct extension and license configured for the Pro client.
Routing_ND can be added to ArcGIS Pro with the Add Data button and is available for network analysis as long as you have the ArcGIS Network Analyst extension and the appropriate StreetMap Premium (*.sdlic) license file installed
https://pro.arcgis.com/en/pro-app/latest/help/data/streetmap-premium/routing-with-streetmap-premium-...
--- George T.
