"Zonal Statistics as Table" failed
4308
11-28-2013 06:13 AM
by Anonymous User
Not applicable
Original User: ianzhangty
Dear GISers,
I have two files, please check google drive: https://drive.google.com/file/d/0B61_JM-jDX9NamNJNUV1Rk5FNnc/edit?usp=sharing
A shape file and a raster file. I want to run Zonal Statistics as Table to calculate the raster statistics with FIPS in shape file. My setting is like that [ATTACH=CONFIG]29440[/ATTACH]
But I got errors
[ATTACH=CONFIG]29441[/ATTACH]
It should be easy and simple, but I really cannot understand why. My version is ArcGIS10.2.
Thank you very much!
Tianyi
DuncanHornby
MVP Notable Contributor
Tianyi,
I have 10.2, just downloaded your data and ran the tool exactly as you had set it up in your images, it ran without error for me!
Suggest you close down ArcMap, start a fresh session and try again?
Duncan
by Anonymous User
Not applicable
Tianyi,
Duncan
Hi Duncan,
That is really strange!! My friend also checked that and found no any error, the same with you.
Will check that. Thank you very much
Tianyi
