Unenabled Pop-Ups in ArcGIS StoryMaps are still Popping Up
3184
9
03-12-2020 11:46 AM
KateBerg2
I don't want any pop-ups on my maps in the ArcGIS StoryMaps Sidecar, so I've un-enabled them on all my layers on my Webmap (right picture below). However, when I click on the layer in the Sidecar, a pop-up still opens! What am I doing wrong?
OwenGeo
Esri Notable Contributor
Hi Kate -- Sorry you ran into this. We are aware of this issue and plan to address it in our upcoming release in a few weeks.
Owen Evans
OwenGeo
Owen Evans
KateBerg2
Sounds good. Thanks, Owen!
KateBerg2
I still see this as an issue, Owen. Is there plans for a future release fixing this?
OwenGeo
Hello Kate -- We fixed the issue we were aware of in our April release. Can you share the map you are having trouble with? Perhaps there is another similar issue or case that we're not aware of.
Owen Evans
KateBerg2
Hi Owen. I cannot share the map yet. We're hoping to make it public in a month or so, but for now, here's what it looks like still (screenshots taken today). Bug is clearly not fixed.
OwenGeo
Hi Kate Berg‌ -- I'm sorry, I believe I was mistaken that the fix for this issue was in our April release. It actually was just deployed last week on Jun 3 (right after we had this conversation). Please test again and let me know if you still see this. I just tested with some other web maps in which this issue was reported and they appear to be behaving as expected now.
Owen Evans
Boyang_Wang
Hi Owen,
I have a question in reverse: how do I turn on popup in Sidecar? I have popup enabled in Map Viewer, but it is not loaded in Sidecar. I am using StoryMap in Enterprise Portal.
Thanks!
OwenGeo
@Boyang_Wang -- Pop-ups should be enabled in your story on any layers where they are enabled in the map. If you are seeing something different on you Enterprise portal, please contact Esri Support and they will be able to help you troubleshoot further.
Owen Evans
Boyang_Wang
Hi Owen,
I figured out that, if a set the symbology of a layer to no color in Map Viewer, the popup will still be enabled in Map Viewer, but not in StoryMaps Sidecar. I changed the symbology and this is now resolved. Perhaps this has something to do with the classic Map Viewer in my Enterprise Portal vs the new Map Viewer in StoryMaps?
Boyang
