Unable to format text in Briefings
1212
05-25-2024 12:12 PM
JimWooten
Hello;
I'm unable to format text (left-, right-, center-justification, text size, font, color) on any slide in Briefings.  See attached.  Did I miss a patch?  Thanks.
Virginia
Hi Jim - From screenshot you attached, it looks like you're attempting to format the text in the slide's title, which is not currently possible using the text toolbar. The text toolbar with the text formatting tools is only currently available when adding text to the slide's main container(s) or body of the slide. You are able to change the color and font of the slide's title in the theme builder and then applying that theme to the briefing.
Virginia
