Not seeing option to add Map Actions
1949
02-06-2021 01:54 PM
by Anonymous User
Not applicable
I want to use map actions in a story map, but do not see the option to either add a map action as a button or as a link. Is there something I am missing like some properties the layer needs to have?
BernSzukalski
Esri Frequent Contributor
Map Actions can be added in any of the Sidecar block layout options (floating or docked). After you choose your map, in the floating or docked panel click (+) to see your options. Map Actions will be among them.
BernSzukalski
OwenGeo
Esri Notable Contributor
For more info and tips on using map actions, see this article.
Owen Evans
