Map tour web map home button behavior
444
11-22-2023 07:48 AM
NigelEdmead
A user has observed that if you click the Home button on a map in the map tour nothing happens. The expected behavior would be to zoom out the the full extent of the map. Since the default is an Esri base map I tried adding a web map with a global extent but still no ability to zoom out.
Anyone else observing this or suggest a solution?
Thanks in advance
AbbyE_Esri
Hi @NigelEdmead ,
Would you be able to share the URL of the story so we can take a look at this behavior? I'm also not seeing the home button's return to the initial default extent after navigating to a point in a different zoom level.
--Abby
