Google Fonts in Enterprise Storymaps
1694
10-27-2022 04:43 AM
Labels (3)
SBark_CBRE
I'm trying to use Google Fonts in my Storymap (ArcGIS Enterprise 10.9.1), but struggling to find the documentation or if it's even possible. What are the steps to do this? I saw the line "To enable Google Fonts for your organization, an administrator must provide a valid Google Fonts API key" but wasn't sure where to provide the key.
Failing access to google fonts, is it possible to upload a custom font and use in Storymaps that I have downloaded? Thanks in advance
AbbyE_Esri
Hello,
To add that Google Fonts API Key, head to your ArcGIS StoryMaps home page, where you can see all of your StoryMaps content. Click your profile image in the top right corner, then select Organization Settings. At the bottom of this Organization Settings page is where you can insert your API key. You will need to be a Portal administrator to implement this change for your organization.
Let me know if this clears things up!
Abby
AbbyE_Esri
Hello,
Abby
