Embed not working in ArcGIS Story Maps
1396
08-27-2024 01:43 PM
BrianneMecum
I am struggling with what seems like a relatively basic function in my Story Map and it's something I've successfully done in the past with Classic Story Maps. I simply want to embed a webpage (a take action page where a user fills in their contact info to sign a petition) at the end of my Story Map. I've generated the iframe code and tested it and it seems to be working correctly, however Story Maps will only let me add it as a card, not interactive content. I'm having no trouble embedding videos (Vimeo, YouTube work fine) but I can't seem to embed this webpage. I've tested it with other web pages and it doesn't work for them either. The page I want to embed is an https site (not http) so I don't think it's that. When I embed a video I'm given all sorts of formatting options, including the interactive content feature. When I embed a webpage it only defaults to creating a card and interactive content is disabled.
What am I missing?
Tags (3)
BenParker
I encountered a similar-sounding problem some time ago. If I recall correctly, I was able to resolve the issue by adjusting the X-FRAME-OPTIONS settings in my website's firewall. Those settings can block embedding by external sites.
ShaneONeill_144
If this is still an issue I would suggest getting in touch with your local Esri Distributor, they can investigate this further for you
Philip_Ruthstrom
Any solutions? We're also experiencing this issue with a video stored in our Azure Storage (and there's no 'x-frame-option' setting available to us).
AravindStoryMaps
Hey Philip,
I was testing out a scenario this morning with Azure. I used the Azure Blob Storage using the steps listed here to upload a MP4 file: https://learn.microsoft.com/en-us/azure/storage/blobs/storage-quickstart-blobs-portal. I set the level of access for my container to Anonymous read access for blobs. I was able to then successfully embed the video in the storymap as a frame and not a card.
If you make a HEAD request to the video url via postman or CURL, do you get back a 200 OK? This usually tells us that the content is able to be shown as an iframe embed instead of a card.
