Can I import Survey123 locations into StoryMap guided tours beta?
358
05-13-2020 09:44 AM
AliciaDe_Toro
I used Survey123 to gather data and would like to use it in guided tours, but it only opens up a manual map option as far as I can tell. Any suggestions. Thanks!
Tags (1)
OwenGeo
Esri Notable Contributor
Hi Alicia -- That's not supported at the moment, but we are looking into an integration between Survey123 and StoryMaps in the future.
Could you provide some more information about what type of survey data you'd like to view as a guided tour? Knowing the specific situation you're interested in supporting would be helpful. For example, are there images collected in the survey? What type of information would you want to put in the description? Does that information come from one field or would there be several fields of information that you'd want to show for each place?
Owen Evans
