ArcGIS StoryMaps- Map Float- Issue: Removes Scale Based Layers
224
a month ago
Amanda__Huber
MVP Regular Contributor
Hello StoryMaps Team,
It appears we found an issue with map float.  When a map has be configured to "Float Left" layers that are set to display at a set visibility scale, the float functionality seems to change the display scale and causes layers to not display in the configured map. When changing this from float to a small/med/large map the layers display as they should.
Web map settings:
Map Float Left issue (parks set at scale don't appear)-
Map when not configured to float (parks set at scale do appear)-
Is this a bug?
Thanks so much,
Amanda Huber
ClioClark
Hi Amanda,
I have just given this a test, and have not been able to replicate using my own StoryMap/data.
Have you enabled the 'Preserve scale' setting in the 'Adjust map appearance' window?
It may also be worth reviewing this blog post: https://www.esri.com/arcgis-blog/products/arcgis-storymaps/constituent-engagement/mapping-with-exten...
If the above doesn't help, I'd be interested to know whether the issue still occurs when using a map with a fresh simple polygon layer (including only a few polygons) in a new StoryMap.
