A recent update to ArcGIS StoryMaps added the ability to copy a link that points to a story heading.
These links can easily be shared so you can direct a colleague or friend right to a specific section of a story, but you can also use these links to create internal story links.
In a future release, we plan to make it easier to create internal story links. For now, you can use this manual, but simple, process to create your own internal story links.
Note that internal links will open in a new tab while you are using the builder, but they will simply jump/scroll the story to the correct location when viewing (or previewing) the story.
For more tips on how to use internal links, check out Add another dimension to your stories with heading links.
