Customizing your StoryMap’s URL
9580
04-12-2021 09:24 AM
OwenGeo
Esri Notable Contributor
5 2 9,580
Some organizations like to customize the URLs for content they publish to increase branding and recognition. While the ability to do this isn’t a feature of ArcGIS StoryMaps at this time, there are ways to do this. This article describes three methods for customizing StoryMap URLs and some of the advantages and things to consider for each.
For simplicity, the rest of this article will refer to stories, but the information also applies for collections.
Create a short link
This method involves creating a memorable or short, shareable link that points to your story. To do this you can use a URL shortener service (such as Bitly) or your IT staff may be able to set up a redirectable link using your organizations domain (e.g., www.my-organization.org/my-story).
The advantages of this method are that it is easy to set up (especially if you use a URL shortening service) and the full shareable link can be customized to your liking. However, when your readers arrive at the story page, they still see aarcgis.com link.
Pros
  • Easy to set up
  • Can customize the entire URL, not just the domain
Cons
  • Does not customize the URL readers see when viewing the story
Use ArcGIS StoryMaps on Enterprise
ArGIS Enterprise provides web GIS capability hosted on your own infrastructureA public-facing Enterprise portal provides domain-specific URLs not only for your StoryMaps, but for all your web GIS content (dashboards, surveys, maps, apps, ...).
ArcGIS StoryMaps is included in Enterprise 10.8.1 and later.
Pros
  • Can utilize existing resources if Enterprise already deployed in your organization
Cons
  • Some StoryMaps features may not yet be available in Enterprise
Embed in a web page
This method requires a few more steps and resources but has several advantages. You create a simple web page with an iframe that embeds the story and set the iframe to take up the full page (100 percent height and 100 percent width). You can name this page whatever you like and host it on your organization’s infrastructure. For more information about embedding, see Take your stories and collections anywhere by embedding them.
Readers will see your page's URL in the browser address bar when they are viewing the story, and everything will appear as if the story is hosted on your own domain. The story URL will be a combination of your organization's domain (www.my-organization.org) and the path/page name you created.
Since you are building the web page, you have the option of adding your own header and/or footer around the story. This can be helpful if you need to provide additional information or formatting that is not supported by the header or credits section of ArcGIS StoryMaps. You can also use other analytics services not natively supported by ArcGIS StoryMaps, like Adobe Analytics.
There are also some potential drawbacks to consider with this approachYou won’t be able to take advantage of several features of ArcGIS StoryMapslike built-in support for Google Analytics and the automatic updates to your story’s metadata for social media sites. If you want to implement these things, you’ll have to manually add them to your custom page (with the help of a web developer).
When using this approach, you should disable the social sharing links in the story header since these tools will point to the story’s arcgis.com link rather than to your custom web page. This change can be made in the story settings.
Pros
  • Appears as if the story is hosted on your website
  • Can customize entire URL, not just the domain
  • Can customize page layout (e.g, add custom header/footer)
Cons
  • May require coordination with web developer and/or IT staff
  • Some built-in features not usable (but can be added manually with additional effort)
2 Comments
KayceeFaunce
While this walkthrough is appreciated, I would like to point out that some agencies are moving away from allowing iframes, as they are viewed as a security vulnerability. These same agencies often have strict visualization identity requirements (headers and footers) - meaning that using Enterprise still isn't a solution. Allowing people to download, customize, and deploy the code on their own domains will ensure that current users are able to continue utilizing these products into the future, rather than seeking out alternatives.
PeterKnoop
MVP Regular Contributor
I'll add one more option: use the Embed widget in Experience Builder Developer Edition with a StoryMap or Collection URL, download the resulting experience, and host it on your own web server. Like the suggestions above, however, StoryMaps and Collections treated this way are not fully functional, so it still isn't a complete solution.
This method does require installing the developer edition of Experience Builder. Once you have created an experience with an embedded StoryMap, however, you can re-use the experience for other StoryMaps simply by changing the URL for the story. In other words, once you've downloaded your experience as a zip file, then you can deploy it multiple times, changing the URL within to point to different stories or collections; the URL is set in .../<name of experience>/cdn/1/config.json. (Note that you cannot switch between URLs for StoryMaps and Collections in the same experience; you need to create one experience for StoryMaps and one for Collections.)
Also note that using this method for stories or collections that are not publicly shared gets more complicated, but it is still doable.
Some of things that don't work with this approach are similar to the above methods, such as built-in support for Google Analytics doesn't work, you are unable to copy URLs for story sections so you cannot direct a reader to a specific section within your story, and the social sharing links do not use your custom URL.
About the Author
Owen is the lead product engineer on Esri's StoryMaps Team and is located in Esri's DC R&D Center in Arlington, VA. He's been with Esri since 2004, and was a Solution Engineer on the National Government Team until 2015. His main areas of interest are StoryMaps and Web GIS and his hobbies include hockey, tech/gadgets, and guitar.
