Zonal Histogram Not Producing a File
1761
11-02-2018 07:12 AM
DaveNuhn
I have been using the Zonal Histogram tool recently but, It just decided to not produce a file. It is a very small amount of data I am working with and computes within seconds. I receive the message that the process is completed but no file is created. Any idea what could cause this issue, I have tried restarting everything and have no luck. I attached a screen shot of the window confirming the process being completed.
DanPatterson_Retired
try adding a *.dbf file extension otherwise it produces an 'info' table
Zonal Histogram—Help | ArcGIS Desktop
and if info tables are anything like esri  grid tables, they hate spaces in paths and files that begin with numbers... like I am seeing in your table of contents.  So they may exist, but you might have to open them manually
DaveNuhn
Dan, thanks for the response. Adding .dbf totally worked, much appreciated.
