Slope percent rise issue
6698
8
08-08-2021 02:48 AM
CarlTaljaard
Hi, I am in desperate need of help. I am trying to generate a slope raster from a 30m DEM in percentage rise, but the resulting values are exactly the same when I run the Slope tool in degrees and in percent rise. Can someone please assist me?
Tags (3)
DanPatterson
MVP Esteemed Contributor
Is the raster in a Projected coordinate system?
How are you comparing the rasters?  (Not visually I hope)
Can you show the raster statistics for both?
... sort of retired...
CarlTaljaard
Hi, Thanks for the quick response!
No, not comparing them visually, the values under the layer at symbology are exactly the same, and for percentage rise the highest value is <90, which cannot be percent as the area definitely has a slope higher than 90%.
I have attached some images, hope they are the ones you were looking for
DavidPike
MVP Frequent Contributor
as Dan say's pretty sure this is a projection issue, Project the raster to planimetric or use the geodesic method on the slope tool.
CarlTaljaard
Hi David, thanks for the advice. I am new to the game, but I think I did project the raster to a planimetric coordinate system, and I definitely tried geodesic as well as planar on the slope tool. I just tried again, no success. I will type my exact steps, can you please take a look and see if you can find my error?
  1. Open new project
  2. Import my 30 m DEM
  3. right click on MAP in the contents pane and change the coordinate system to WGS 1984 UTM Zone 36S (this is where I am working) see attached image
  4. Select slope tool (see image)
  5. input raster is the DEM
  6. Output measurement is percentage rise
  7. Method (tried both planar and geodesic)
  8. The result is still in degrees (see image)
I really hope you can find my mistake
DavidPike
The projection you have defined is for the Map/Data Frame.  To my knowledge this is honoured in some but very few geoprocessing tools.  What is the output if you use GEODESIC method? or if you use the Project Tool to actually project the elevation into that UTM zone, then run the slope on that new raster.
CarlTaljaard
Here is the output using the geodesic method.
I will quickly try the projectingtool
CarlTaljaard
No Success... I took screenshots of every step I took. Will you please check them?
Thank you for helping me
tlopezcantu
Hi CarlTaljaard,
Could you please share with us the ArcGIS Pro version that you are using? If by any chance, you are using 2.7, could you please update your ArcGIS Pro 2.8 and try using the Slope tool again?
If updating ArcGIS Pro does not solve your issue, could you please post here the raster statistics for both the Percent Rise output and the Degree output? I think you only shared the raster statistics for one output above. I will reach out to you for more information in case the statistics look erroneous!
Please also let us know if updating the Pro version worked!
Thank you,
Tania Lopez-Cantu
