Raster Radiation Tool Weather Conditions
787
02-27-2025 08:01 AM
Ed_
by MVP Regular Contributor
Hello, how does the tool factor in the weather conditions? For example, a place in Texas may have much more daily solar charge potential than say Chicago or Boston or Seattle. So, depending on an area's weather conditions, investment in solar panels may not be viable. The tool does have two Diffuse Model Types, Uniform Sky and Overcast Sky, how does these two model factor in daily weather conditions which vary from place to place?
Are there other tools for such an analysis that can be in conjunction with Raster Solar Radiation.
Question | Analyze | Visualize
DanPatterson
MVP Esteemed Contributor
How Raster Solar Radiation works—ArcGIS Pro | Documentation
These tools provide a baseline based on latitude which can be calculated for any location.  If a surface has a slope and orientation, then the flat surface values can be modified to account for these.  All calculations presume a clear sky (atmospheric thickness and turbidity can be factored if one has real world values comparing actual to theoretical values)
No model is going to be able to factor seasonal/daily/hourly changes in the "weather".
  Sky conditions can ony be modelled by an atmospheric turbidity.
Now Solar Resource Maps and Data | Geospatial Data Science | NREL | Geospatial Data Science | NREL
should it still be active, may be a place to consult to compare latitudinal potentials vs site specific ones, which may account for real world measurements.
If you want real values, then you have to consult your climate normals for the amounts of direct and diffuse solar radiation collected.  Some places can give an estimate of actual versus clear sky (theori
... sort of retired...
Ed_
Thanks Dan, it would be nice to have the tool and maybe even the Feature Radiation tool to have weather related optimization baked in it.
DanPatterson
ps... my undergraduate thesis
Global Irradiance on Slopes
1977
And the sun still shines in most places the same way 😂
Ed_
Can't wait for the sun to some more when winter is over and i can't hit the beach lol
