Raster' object is not iterable
3906
07-23-2014 08:34 AM
InceptionWoznicki
Hi Guys,
I 'm trying to calculate the percentage of cell counts in new raster and the new raster is created from an old raster based on the Value > 14. In my code, 1st for loop is for original raster and keeping the value and count fields in a dictionary. Then, creating new raster using Value > 14. The 2nd for loop is for the new raster and keeping its value and counts of in a new dictionary and finally calculating the percentage.
However, I am getting an error on the 2nd for loop. The error says " 'Raster' object is not iterable". Anybody has any suggestion. Thank you for your help!
Code:
import arcpy, os
from arcpy import env
from arcpy.sa import *
#To overwrite output
arcpy.env.overwriteOutput = True
#Set environment settings
env.workspace = "C:/Subhasis/Test/Neshanic_Python"
outws="C:/Subhasis/Test/Neshanic_Python/extract"
#checkout ArcGIS spatial analyst extension license
arcpy.CheckOutExtension("Spatial")
# set local variable
inraster = ["01367620-r-r"]
for i in inraster:
    flds = ("VALUE", "COUNT")
    dct = {row[0]:row[1] for row in arcpy.da.SearchCursor(i, flds)}
    sumcnt = sum(dct.values())
    newraster = ExtractByAttributes(str(i), "VALUE>=14")
    for j in newraster:
        flds1 = ("VALUE", "COUNT")
        dct1 = {row[0]:row[1] for row in arcpy.da.SearchCursor(j, flds)}
        sumcnt1 = sum(dct1.values())
        percentage=(sumcnt/sumcnt1)
        print percentage
Tags (1)
XanderBakker
Esri Esteemed Contributor
Hi Subhasis,
I notice you have 5 separate threads on more or less the same topic:
Inception Woznicki‌ (just look at the content)
I have a few recommendations:
  • Concentrate on this topic: loop for value and counts in raster attribute is has the most answers.
  • If there are helpful comments mark them as helpful, it will help other user to find useful content faster
  • If a question was answered mark the thread as answered at the right comment, this also helps the community to find useful content, and avoids people to invest their time in your question, if your question was already solved.
Kind regards, Xander
XanderBakker
Hi Subhasis,
InceptionWoznicki
Hi Xander,
This is a pretty good suggestion. I marked it as answer.
Regards,
Subhasis
