I want to be able to use the Auto Georeference tool in Pro in a script. I don't see any documentation for this in the arcpy documentation. Anyone have any ideas ?
Adam
Perhaps you are after the Register Raster Tool
not directly, but as indicated...
Register Raster (Data Management)—ArcGIS Pro | Documentation
then you can use
Warp From File (Data Management)—ArcGIS Pro | Documentation
you can code the access via
arcpy.WarpFromFile_management(....
or even
arcpy.Warp_management(....
Thanks Dan!
I got it working with that tool. What would you use the WarpFromFile for ? Doesn't the register raster do what I need.
Adam
