Is there a tool to convert the cells of a raster to vector?
5180
04-12-2011 09:56 AM
JamalNUMAN
Legendary Contributor
Please, see the attached raster
Is there a way to get the cells on this raster to vector such that each cell becomes a square in the vector class, therefore, the vector will contains feature equal to number of cells in the raster
Of course, I know the tool ???raster to polygon???, but his doesn???t give the vector with individual squares
Thank you
Regards
Jamal
Jamal Numan
TimothyHales
Esri Notable Contributor
Check out this older forum post: http://forums.esri.com/thread.asp?c=93&f=986&t=227834
If that tool is what you are looking for then you can get the latest version of the tool here: http://www.spatialecology.com/gme/
EricRice
Jamal,
We intentionally dissolve the pixel boundaries (for continuous pixel values) so the output is not so large.  This is also why we do not allow you to convert float rasters to polygons.  You could potentially end up with billions of polygon records depending on the size of your raster.  I would suggest using the Create Fishnet tool that is part of core ArcGIS Desktop.  It might take a long time to process if you are going to be creating a lot of cells.
If you need to have the raster value associated with the fishnet polygons, convert your raster to points and do a spatial join.
Regards,
Eric
SteveLynch
Use the following 3 GP tools
Create Fishnet
- extent = raster extent
- cell size width/height = raster cell size
- number of rows/columns = number of rows/columns of raster
- Geometry type = Polyline
Raster To Point
Feature To Polygon
- Input features = Fishnet output
- Label Features = Raster To Point output
JamalNUMAN
thank you Eric. it did work.
appreciated
jamal
Jamal,
Regards,
Eric
Jamal Numan
JamalNUMAN
Greate eleboration Steve. thank you
Jamal
Create Fishnet
Raster To Point
Feature To Polygon
Jamal Numan
