Intersecting a flood raster with a population grid
1613
08-21-2018 10:50 AM
deleted-user-qIrrkfi_YpZh
I have two rasters: a flood inundation raster (depth grid) and a census grid. I would like to know how many people are affected at 0-1 feet, 1-3 feet, 3-6 feet, 6-9 feet, and more than 9 feet. I need to figure out how many are effected in each class (a count). What tool(s) do I need to use? Do I need to convert one (or both) rasters to a polygon? Thanks in advance!
DanPatterson_Retired
Combine—Help | ArcGIS Desktop
will give you all the combinations.  You have integer rasters and they are classified..
If your population isn't in classes, then
Zonal Statistics as Table—Help | ArcGIS Desktop
might do it
You should do the conversion to raster explicitly because you will need to establish the cell size, processing extent and set your snap raster (to the existing raster extent)
XanderBakker
Esri Esteemed Contributor
In addition to what Dan mentions, if your population is expressed as density you will need to convert the density to number of people using the area of overlap. If they are absolute values, use the fraction of overlap to get the correct number of people.
Wouldn't I need to convert my flood inundation raster to polygon so I had a "zone" to refer to?
My census grid is number of # people/cell
zonal statistics as table will convert a polygon back to a raster in any event...  check the link I posted
