I have two point layers (layer-1 and layer-2).
- I used 'Generate Near Table' to identify connections between points in layer-1 and layer-2. I used a search radius of 5000m and maximum number of closest of 10.
- I then used the 'XY To Line' tool to create connection lines between the connections identified in the first step.
Issue: some points in layer-1 are connecting to less than 10 points in layer-2 although there are more layer-2 points within the 5000m radius.
In the attached image the three green lines are generated by ArcGIS and orange broken-lines are not generated but are within the 5000m radius.
What could be the reason and how do I correct this?
Software: ArcGIS Pro 2.6.0
