Hi Guys,
I have a silly question to ask. Using the below code, I want to extract a new raster from an original raster using value field and I want to automate the process for 70 more rasters. However, for testing purpose, I 'm using only 3 rasters.
Out of 3 rasters inside the working directory, this code works only for one raster which has both " ESRI grid" and "info" folder inside the working directory. I was not able to keep the "info" folders of other two raster inside the working directory as the "info" folder of 1st raster is already in the working directory.
I know it is stupid question. But could you please let me know how can i keep the "info" folders of other two rasters inside the working directory, so that code will work and I can automate the process?
Thank you very much for your time and help!
Code:
import arcpy,os
from arcpy import env
from arcpy.sa import *
#To overwrite output
#Set environment settings
env.workspace = "C:/Subhasis/Test/Neshanic_Python"
outws="C:/Subhasis/Test/Neshanic_Python/extract"
#checkout ArcGIS spatial analyst extension license
arcpy.CheckOutExtension("Spatial")
# create a list of all rasters in current workspace
lst_ras = arcpy.ListRasters()
threshold = 0.75
for ras in lst_ras:
flds = ("VALUE", "COUNT")
dct = {row[0]:row[1] for row in arcpy.da.SearchCursor(ras, flds)}
sumcnt = sum(dct.values())
threscnt = sumcnt * threshold
cnt, result = 0, 0
for k in sorted(dct):
cnt += dct
# print " - Value = {0}, Sum = {1}".format(k, cnt)
if cnt < threscnt:
result = int(k)
else:
break
print "Threshold = {0}".format(result)
attExtract = ExtractByAttributes(ras, "VALUE>={0}".format(result))
outname = os.path.join(outws,"{0}{1}".format(ras, result))
attExtract.save(outname)
arcpy.CheckInExtension("Spatial")
