Differences between results obtained with Raster Calculator and Map Algebra (VB)
7346
9
08-07-2014 07:05 AM
CarlesMiquel
I would want to work with Map Algebra launched in VB from ArcGis 9.3.
The results obtained, are a little bit different from those obtained with Raster Calculator.
Does someone know where could be the problem?
Thank you very much,
Carles.
curtvprice
If the same map algebra expression generates different results when called from different environments (for example, from running the 9x Raster Calculator tool, ModelBuilder, or using a geoprocessing tool), I believe a good place to start is to verify the environments used -- cell size, extent, coordinate system, etc. -- and make sure they are the same.
In 9.x this is particularly problematic as the the Raster Calculator (and VB/VBA calls to RasterOp objects) observe the ArcObjects settings (set in the Spatial Analyst toolbar Options), while the map algebra geoprocessing tools (SOMA, MOMA) use the (perhaps different) settings in the geoprocessing environment. In 10.x, all spatial analyst tools use the geoprocessing environment -- much less confusing that way!
DanPatterson_Retired
Examples would be great...the syntax and the outputs would be useful
curtvprice
CarlesMiquel
Thank you to both,
I am sure you are right Curtis, but I don't know how the environment settings could be fixed in VBA for Map Algebra. As suggested by Dan, I attach the code used just in case it could help to bring more information.
Carles.
Sub Map_algebra_calculation(calculation_text As String, Output_raster_name As String)
    strData = "C:\OUTPUT_PATH\"
    Dim pMxDoc As IMxDocument
    Set pMxDoc = ThisDocument
    Dim pMap As IMap
    Set pMap = pMxDoc.FocusMap
    Dim pRLayer As IRasterLayer
    Dim pLayer_AAA As ILayer
    Dim pInRaster_AAA As IRaster
    Dim pLayer_BBB As ILayer
    Dim pInRaster_BBB As IRaster
    Dim pLayer_CCC As ILayer
    Dim pInRaster_CCC As IRaster
    Dim pLayer_DDD As ILayer
    Dim pInRaster_DDD As IRaster
    Dim pLayer_EEE As ILayer
    Dim pInRaster_EEE As IRaster
   ' Create a Spatial operator
   Dim pAlgbOp As IMapAlgebraOp
   Set pAlgbOp = New RasterMapAlgebraOp
   Set pLayer_AAA = pMap.Layer(2)
   Set pRLayer = pLayer_AAA
   Set pInRaster_AAA = pRLayer.Raster
   Set pLayer_BBB = pMap.Layer(3)
   Set pRLayer = pLayer_BBB
   Set pInRaster_BBB = pRLayer.Raster
   Set pLayer_CCC = pMap.Layer(4)
   Set pRLayer = pLayer_CCC
   Set pInRaster_CCC = pRLayer.Raster
   Set pLayer_DDD = pMap.Layer(5)
   Set pRLayer = pLayer_DDD
   Set pInRaster_DDD = pRLayer.Raster
   Set pLayer_EEE = pMap.Layer(6)
   Set pRLayer = pLayer_EEE
   Set pInRaster_EEE = pRLayer.Raster
    ' Bind a raster
    Call pAlgbOp.BindRaster(pInRaster_AAA, "AAA")
    Call pAlgbOp.BindRaster(pInRaster_BBB, "BBB")
    Call pAlgbOp.BindRaster(pInRaster_CCC, "CCC")
    Call pAlgbOp.BindRaster(pInRaster_DDD, "DDD")
    Call pAlgbOp.BindRaster(pInRaster_EEE, "EEE")
    ' Set output workspace
    Dim pEnv As IRasterAnalysisEnvironment
    Set pEnv = pAlgbOp
    Dim pWS As IWorkspace
    Dim pWSF As IWorkspaceFactory
    Set pWSF = New RasterWorkspaceFactory
    Set pWS = pWSF.OpenFromFile("C:\OUTPUT_PATH\TEMP", 0)
    Set pEnv.OutWorkspace = pWS
    ' Perform Spatial operation
   Dim pOutRaster As IRaster
    ' Defineix les variable de la iteracio de l'Excel llegit
    ' Dim Texte_calculadora_raster As String
   '  Set Texte_calculadora_raster = calculation_text
    ' Dim Nom_fitxer_sortida As String
   '  Set Nom_fitxer_sortida = Output_raster_name
    'aquí comança el càlcul de la regressio multiple
    Set pOutRaster = pAlgbOp.Execute(calculation_text) '(Texte_calculadora_raster)
' Unbind rasters
     Call pAlgbOp.UnbindRaster("AAA")
     Call pAlgbOp.UnbindRaster("BBB")
     Call pAlgbOp.UnbindRaster("CCC")
     Call pAlgbOp.UnbindRaster("DDD")
     Call pAlgbOp.UnbindRaster("EEE")
    ' Add it into ArcMap
    Set pRLayer = New RasterLayer
    pRLayer.CreateFromRaster pOutRaster
    ' Add its name (Output raster name)
    pRLayer.Name = Output_raster_name pMap.AddLayer pRLayer
    Call createFileFromRaster(pOutRaster, strData + pRLayer.Name)
End Sub
curtvprice
I believe these settings are properties on your pEnv (IRasterAnalysisEnvironment) object. I would query your pEnv object and see if the values are the same that were set in the Spatial Analyst toolbar options when you ran the Raster Calculator. it's true the Raster Calculator interface is different from the raster tools and this a major reason it went away at 10.x.
Have you considered eschewing the the ArcObjects Ops and instantiate a geoprocessor object instead so you can use the single-output map algebra tool - this lets the GP do a lot of the work for you -- a lot less code! A side benefit of doing it that way is your code will be a lot more portable to 10.x.  Also, note that VBA is deprecated from 10.x on.
CarlesMiquel
Thank you all.
I am not an expert in programming code and do not know how to set and write this environment.
Could someone posting an example setting all the properties of an pEnv (IRasterAnalysisEnvironment) object?
Thank you very much.
Carles.
curtvprice
I am not a developer either, but it seems pretty straight forward, along the  lines of:
cell_size = 30
Dim pRasEnv as IRasterAnalysisEnvironment
pRasEnv.SetCell(esriRasterEnvValue, cell_size)
I still think going to geoprocessing is an easier path - and more forward-compatible.
CarlesMiquel
Thank you Curtis,
I will try your example. I tried geoprocessing with an adapted code in the base of this one, but the results are very different from the ones obtained with the raster calculator. I don't know where the problem is.
Do you have an idea?
# Create the Geoprocessor object
gp = arcgisscripting.create()
try:
  # Set local variables
  InExpression = "focalsum(C:/data/flowdir, Circle, 3)"
  OutRaster = "C:/data/soma01"
  # Check out Spatial Analyst extension license
  gp.CheckOutExtension("Spatial")
  # Process: MapAlgebraStatement
  gp.SingleOutputMapAlgebra_sa(InExpression, OutRaster)
except:
  # If an error occurred while running a tool, then print the messages.
  print gp.GetMessages()
CarlesMiquel
Dim gp As Object
    Set gp = CreateObject("esriGeoprocessing.GPDispatch.1")
    gp.CheckOutExtension "spatial"
    gp.AddToolbox "C:/Program Files/ArcGIS/ArcToolbox/Toolboxes/Spatial Analyst Tools.tbx"
    Dim StrDataComplerta As String
    StrDataComplerta = StrData + nom_raster_sortida
    gp.SingleOutputMapAlgebra_sa text_calcul, StrDataComplerta
CarlesMiquel
Thank you Curtis,
An how could I define the other parametre from pEnv (Extent as interesection, etc...)?
