Default Raster Mask for Raster Calculator
2196
09-14-2011 05:42 PM
MichaelDenslow
How do you set the default raster mask for Raster Calculator in ArcGIS 10?
In 9.x I used to do this by Spatial Analyst - Options - Raster Mask. Now the only option I see is to set it in Environments at the bottom of the Raster Calculator window. Expand the Raster Analysis options and select the Mask. This has to be done for each new calculation, which is not ideal.
Thanks!
DuncanHornby
MVP Notable Contributor
Open Arctoolbox window, right click on the root ArcToolbox and select environments...
Duncan
MichaelDenslow
That's it. Thanks!
