Change pixel depth of rasterfile
16559
04-16-2018 10:01 AM
sadiajame
I have ten raster files to work on their pixel depth is 32 bit and one of them is 2 bit. I need to mosaic them but they are not doable as all of them are not in the same pixel size. How can I change it?
- Thank you!
DanPatterson_Retired
Set the extent and cell size and you can use Resample http://pro.arcgis.com/en/pro-app/tool-reference/data-management/resample.htm
When running the tool, ensure that you check the Environments to ensure everything is as you need
sadiajame
Thank you for your time.
AbdullahAnter
Honored Contributor
sadiajame
Thank you so much Abdullah. It works!
