Can´t use the Spatial Analyst Extension in the Evaluate Period
2138
6
10-26-2011 06:35 AM
DosPanes
Hi guys,
I´m currently evaluating the Arc GIS 10 version and i`m unabled to use the extensions. They are all activated under customize -> extensions. Commanding via Python also won`t work since it teels me that the tool is not licenced. Did anyone of you have a similar problem and found out how to fix it?
Greets,
Dospanes
Zeke
Honored Contributor
Have you actually downloaded the extensions? They're not automatically installed even though they show up in the Customize menu. In 10, Start - All Programs - ArcGIS - ArcGIS Administrator and go from there.
DosPanes
yes they are all installed. i checked unter "availability" and tehy are all installed an authorized. hummm..thats so strange.
DosPanes
ok i got it. I can`t use the tools via Python and i can`t find them in the search window (i dont know why). But i can access them searching manually in the toolbox...
Zeke
Honored Contributor
Yes, didn't think of that. The SA toolbar has been greatly reduced between 9.3 and 10. Why, no idea.
EricRice
Did you import the spatial analyst module?
# Import system modules
import arcpy
from arcpy.sa import *
Did you check out the spatial analyst license?
# Check out the ArcGIS Spatial Analyst extension license
arcpy.CheckOutExtension("Spatial")
Regards,
Eric
DosPanes
hi eric,
yes i loaded the module and checked out the license. I actually followed the steps on: http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//009z0000000s000000.htm
Since it was only one kernel operation there is no problem for now doing it via the toolbox.
thx for the advice!
