Calculating percentage of slope and aspect for each parcel
3096
5
10-08-2021 02:06 PM
JohnnyHarley232
Hello! I have a task where I thousands of parcels and calculate slope and divide the raster into low, medium, and high slope. Then from there, give the percentage of each category for each parcel. I have successfully calculated slope (degrees) for my dataset and converted the raster in polygons and then performed a Tabular Intersection tool to determine percentage of each category for each parcel.
Now the hard part. I need to determine the direction of aspect for each parcel. is there a way to calculate what the majority aspect is for a zone or boundary?
DavidPike
MVP Notable Contributor
Zonal Statistics as Table (Spatial Analyst)—ArcGIS Pro | Documentation should be pretty painless, use the MAJORITY option.
JohnnyHarley232
Hi David, unfortunately, when calculating Aspect.. Zonal Statistics by Table doesnt bring up Majority as an option when calculating statistics!
DanPatterson
If the value input is floating point, the Majority, Minority, and Variety statistics are not available for calculation.
Majority, Minority and Variety are characteristics of nonparametric data.  Think of it as counts of data and since interval/ratio data have a fineness of scale that isn't inherent in classed or ordinal data, because of it.
Class the data into groups as David suggests and use that or produce those values
I would caution against using "mean" or other such statistical measures since circular data (eg aspect) requires special calculations for those (Google statistics for directional data or similar terms
... sort of retired...
DavidPike
ah of course.  Probably Reclassify (Spatial Analyst)—ArcGIS Pro | Documentation into your N,NE.. bands.  Hopefully with your symbology set as that renderer, the tool will populate the class breaks for you also.
Surface Aspect (3D Analyst)—ArcGIS Pro | Documentation might also do the leg-work for you.
RyanDeBruyn
This post might be of some help for reference.   See the CalcZonalMeanAspect sample.
Calculate mean aspect for polygons
