Buffer by elevation
5602
03-12-2012 05:32 AM
StacyCulpepper
Would anyone be able to direct me to the right tool or tools that will take a POLYLINE (or polyline raster) overlain with a DEM raster, and obtain a 5 feet HIGHER area than the height of the floodplain boundary?   Many places say to use the Euclidean Allocation tool, but the documentation for that is lacking -in my opinion.  It does not perform the function I'm seeking.
Thank you.
Stacy
DarrenWiens2
This is probably oversimplistic, but can't you make contours of your DEM and extract the contour line you're interested in? It seems to me that your floodplain polyline should all fall at one elevation, but this may not be the case...
VinayAchrekar2
Has anyone found an answer to this?
StacyCulpepper
I for one, was never given a satisfactory answer. I'm not still looking
either. The project I needed that info for was 3 years ago, haven't needed
it since.
Stacy
XanderBakker
Esri Esteemed Contributor
Not entirely sure, but you can probably use the script in this post to get that result (although you are not looking for a floodplain):
Determine Floodplain: Based on known flood level
