Attempting to do IDW, error "not enough points"
1790
09-15-2011 02:22 AM
chriscoulter
I have a point set that I select in the IDW input menu, it has over 4000 points.  But when I attempt to run the interpolation it gives me the error message that i do not have enough.  Help says i need 2 points to do this.  Obviously i have more.
I was able to create a thiessen polygon set with the points without error.  Also this error comes up when i try Spline and Kriging.  I am stuck asking for some assistance please.
DanPatterson_Retired
Check to ensure that you don't have a single point selected by opening the files table and looking at the selection numbers at the bottom of the table
chriscoulter
Thank you, you are correct!
