Area Solar Radiation tool of the Spatial analyst
4744
6
04-07-2015 04:02 AM
bala_bhavyakausika
I'm working with the Area Solar Radiation tool of the Spatial analyst. I am using Lidar data for a part of Netherlands and am running the model for the whole year with monthly interval and I get highest insolation values for the month of November instead of July or August. I tried it a couple of times and also using a python script but still the same problem. Could anyone help me in explaining this?
NeilAyres
What is the coordinate system for your data?
Is it in Holland....
bala_bhavyakausika
Yes 52.1 N Latitude
NeilAyres
This "52.1 N Latitude" is not a coordinate system.
Is the data in a projected coordinate system? This is recommended for this tool (and for most other analytical tools. If it is projected, then you don't have to specify a mid latitude for the data, because the system will already know that.
bala_bhavyakausika
Yes it is Projected. Amersfoort_Double_Stereographic projection.
NeilAyres
Can find no reference to that in the ArcGIS documentation. Just something called RD New and RD Old.
So, is the DEM in metres (X, Y and Z).
What is the EPSG code for "Amersfoort_Double_Stereographic projection"
bala_bhavyakausika
Sorry. The projection is RD New.
