Analysis of overlaying rasters
6348
22
02-05-2015 12:28 PM
NicolasBeerli
Hi everyone,
I have around 1000 raster data layer. Every single one represents a distribution range of a species.
In the attribute table of each raster data layer are the body measurements of the specimen (there is only
one row per attribute table).
I am looking for a method in which I could calculate for each pixel the mean body size of the overlaying rasters.
Is there something like that? It would be best if I could repeat that for severals columns in the attribute table.
Is there a more or less simple solution for this problem? Haven't found anything till now..
Many thanks,
Nicolas
Tags (1)
XanderBakker
Esri Esteemed Contributor
It may take some time to work out the idea I have. I started on another method, but maybe I will have to adapt this based on the data provided. I will get back to you as soon as I have something to show.
Kind regards, Xander
XanderBakker
This is what I came up with until now (the code is still messy, but it threw out some results that look promising).
I have attached the geodatabases used for and create in the process.
Let me know if you run into problems.
I changed the name of 1 raster that wasn't listed in the csv to make it match the list of raster names in the csv (although that is wrong).
# Name:        analyzeSpecies.py
# Purpose:    raster overlay attribute analysis
# Author:      Xander
# Created:    10-02-2015
def main():
    import arcpy
    import os
    # input settings
    ws_ras = r"D:\Xander\GeoNet\SpeciesRaster\gdb\rasters.gdb"
    ws_pol = r"D:\Xander\GeoNet\SpeciesRaster\gdb\polygons.gdb"
    tbl_species = r"D:\Xander\GeoNet\SpeciesRaster\gdb\tables.gdb\SpeciesData"
    fc_out = r"D:\Xander\GeoNet\SpeciesRaster\gdb\result.gdb\result"
    # field names
    fld_raster = "Name_SP"
    fld_TW = "TW_SMUNDI_1"
    fld_BL = "BL_SMUNDI_1"
    fld_FL = "FL_SMUNDI_1"
    lst_flds = [fld_TW, fld_BL, fld_FL]
    # internal names
    fcname_merge = "merged"
    fcname_area = "aoi"
    fcname_intersect = "intersect"
    # path to tmp fc's
    fc_merged = os.path.join(ws_pol, fcname_merge)
    fc_area = os.path.join(ws_pol, fcname_area)
    fc_intersect = os.path.join(ws_pol, fcname_intersect)
    # dct with fields, input and output
    dct_flds = {}
    for fldname in lst_flds:
        dct_flds[fldname] = "{0}_Mean".format(fldname[:2])
    # create dictionary from species tabel (raster name vs stats)
    flds_species = [fld_raster]
    flds_species.extend(lst_flds)
    dct_SpecieStats = {r[0]: [r[1], r[2], r[3]] for r in arcpy.da.SearchCursor(tbl_species, flds_species)}
    # list polygons fc's
    lst_polfcs = []
    # list rasters and batch convert rasters to polygons
    arcpy.env.workspace = ws_ras
    lst_ras = arcpy.ListRasters()
    cnt = 0
    for ras in lst_ras:
        cnt += 1
        raster = os.path.join(ws_ras, ras)
        fc_pol = os.path.join(ws_pol, ras)
        print " - RasterToPolygon_conversion: {0}".format(ras)
        # raster to polygon
        arcpy.RasterToPolygon_conversion(raster, fc_pol, simplify="NO_SIMPLIFY")
        # add fields to polygons
        print " - AddDoubleField"
            AddDoubleField(fc_pol, fldname)
        # update values in polygon fc
        print " - UpdateCursor(fc_pol..."
        with arcpy.da.UpdateCursor(fc_pol, lst_flds) as curs:
            for row in curs:
                if ras in dct_SpecieStats:
                    lst_val = dct_SpecieStats[ras]
                    row[0] = correctValue(lst_val[0])
                    row[1] = correctValue(lst_val[1])
                    row[2] = correctValue(lst_val[2])
                    curs.updateRow(row)
                else:
                    row[0] = -1
                    row[1] = -1
                    row[2] = -1
                    curs.updateRow(row)
        # add to list to append or merge
        lst_polfcs.append(fc_pol)
        # sr
        if cnt == 1:
            sr = arcpy.Describe(fc_pol).spatialReference
        # merge and append featureclasses
        if cnt % 50 == 0:
            if cnt == 50:
                # merge
                arcpy.Merge_management(lst_polfcs, fc_merged)
                lst_polfcs = []
            else:
                # append
                arcpy.Append_management(lst_polfcs, fc_merged, "NO_TEST")
                lst_polfcs = []
    # append the last fc's
    print " - after loop, append or merge"
    if cnt < 50:
        # there is no merged fc, so use merge instead of append
        if len(lst_polfcs) > 0:
            lst_polfcs = []
    else:
            lst_polfcs = []
    # create area fc (extent of merged fc)
    print "createRectangleExtendFC"
    rectangle = createRectangleExtendFC(fc_merged, sr)
    arcpy.CopyFeatures_management([rectangle], fc_area)
    # execute intersect
    print "Intersect_analysis"
    arcpy.Intersect_analysis([fc_merged, fc_area], fc_intersect)
    # create empty output fc
    print "CreateFeatureclass_management"
    fc_ws, fc_name = os.path.split(fc_out)
    arcpy.CreateFeatureclass_management(fc_ws, fc_name, "POLYGON", spatial_reference=sr)
    # add output fields
    print "AddDoubleField output"
        fldname_stat = dct_flds[fldname]
        AddDoubleField(fc_out, fldname_stat)
    # only use gridcode = 1
    where = "{0} = {1}".format(arcpy.AddFieldDelimiters(fc_intersect, "gridcode"), 1)
    # start analysis of unique polygons
    print "start analysis of unique polygons"
    dct_geo = {}
    dct_att = {}
    flds_stat = ["OID@", "SHAPE@"]
    flds_stat.extend(lst_flds)
    with arcpy.da.SearchCursor(fc_intersect, flds_stat, where_clause=where) as curs:
        for row in curs:
            oid = row[0]
            polygon = row[1]
            lst_val = [row[2], row[3], row[4]]
            dct_att[oid] = lst_val
            j = polygon.JSON
            if j in dct_geo:
                lst_oid = dct_geo
                lst_oid.append(oid)
                dct_geo = lst_oid
            else:
                dct_geo = [oid]
    del row, curs
    # calc stats
    print "calculate statistics"
    dct_res = {}
    for i in range(0, 3):
        for j, lst_oid in dct_geo.items():
            lst_val = [dct_att[oid] for oid in lst_oid]
            tot = sum(lst_val)
            cnt = len(lst_val)
            mean = tot / float(cnt)
            oid_first = lst_oid[0]
            if oid_first in dct_res:
                lst_mean = dct_res[oid_first]
                lst_mean.append(mean)
            else:
                lst_mean = [mean]
                dct_res[oid_first] = lst_mean
    # insert values
    print "insert values into output fc"
    flds_out = ["SHAPE@"]
        flds_out.append(dct_flds[fldname])
    # insert cursor
    with arcpy.da.InsertCursor(fc_out, flds_out) as curs_out:
        # search cursor
        with arcpy.da.SearchCursor(fc_intersect, ("OID@", "SHAPE@")) as curs:
            for row in curs:
                oid = row[0]
                if oid in dct_res:
                    polygon = row[1]
                    lst_mean = dct_res[oid]
                    curs_out.insertRow((polygon, lst_mean[0], lst_mean[1], lst_mean[2], ))
    print "ready..."
def AddDoubleField(fc_pol, fldname):
    if len(arcpy.ListFields(fc_pol, wild_card=fldname))==0:
        arcpy.AddField_management(fc_pol, fldname, "DOUBLE")
def correctValue(val):
    if type(val) == float:
        return val
    else:
        return float(val)
def createRectangleExtendFC(fc, sr):
    ext = arcpy.Describe(fc).extent
    props = ["lowerLeft", "upperLeft", "upperRight", "lowerRight", "lowerLeft"]
    arrPnts = arcpy.Array()
    for crnr in props:
        arrPnts.add(eval("ext.{0}".format(crnr)))
    return arcpy.Polygon(arrPnts, sr)
if __name__ == '__main__':
    main()
NicolasBeerli
Hi Xander,
I don't have experience with python. So it will take a bit to figure it out for me. But after all problems I had with the model builder I think it is anyway a must to know python. I let you know when I run in problem thanks.
Many thanks,
Nicolas
