"zonal statistics as table" output table error
1267
07-25-2011 09:41 AM
KathrynProciv
I have a question regarding running "Zonal Statistics as Table" in Arc10.  I've tried running it dozens of times and keep getting the message "WARNING 000870 Output table:[my folder location] exists. It will be overwritten."  I've tried changing the location of the table, as well as changing the name of my output table and I continue to get the error message.  A table even shows up in ArcCatalog, but it's empty.  What's weird is I was able to run "Tabulate Areas" successfully, and even the regular "Zonal Statistics."  It just won't let me output as a table.
Any suggestions would be greatly appreciated!
Thank you so much,
Kathryn
Annisa_IndahSari
I have also the same problem!
When I change the data size with a smaller one. It does work perfectly!
Dont know why (?)
