A grid applied in a sum of polygons included(how to analize polygon in polygon)!
769
04-16-2011 09:27 AM
AdrianCovasnianu
Hello!
I have a delimited polygon. Within this polygon I have a total of X polygons included in the current full/total polygon. These X polygons differs by shape. What I want is to see the overlapping times (something like a repetitive case), in order to interpolate the resulted polygons.
My idea is to apply a grid (X*Y meters/kilometers) needed to see how many times those polygons are present in the grid sections. By applying this grid it should suggest me the polarization of the polygons.
This polygons are limits of the towns influence in matter of public interest.
I've tried with intersect and union geo-processing tools but no result. 😞
Can you suggest me any solution ?
Thanks!
curtvprice
What was the problem with the union processing -- did the tool fail, or did the result not have the results you needed?
Have you considered doing the analysis in the raster domain using the Combine tool? This tool would give you a table of every unique combination of inputs at each cell which can then be used with the Pivot Table tool (or exported to a database or spreadsheet) for summarizing the combinatorial analysis results.
