Water Utility Hydrant Inspections - Added Fields
1743
07-31-2023 11:28 AM
HMarcks
I have additional fields in my inspection table that are not in the original solutions and I am having quite the time trying to add them to the Hydrant Inspection Field Maps table form while ensuring the yes/no toggle switch works. I have tried to make sure my original fields have defaults activated etc. but when I add the fields into the form they always revert to a combo box instead of the toggle. Any advice?
JoelSmith3
Esri Alum
Adding the new field and setting the default in the Template section in Field Maps Designer fixed the issue!
JoelSmith3
Esri Alum
I'd like to work with you to resolve this issue, could you email me: j.smith@esri.com
Joel
JoelSmith3
Esri Alum
HMarcks
Thank you!  I was not aware of how to get into the Template (I believe I was viewing it from Map Viewer forms) and was going in circles trying to get this sorted out.
