The mxd map attached to a job type is not displayed in the Workflow manager,
3892
08-26-2013 08:51 AM
by Anonymous User
Not applicable
Original User: Jamal432@gmail.com
Two mxd maps are attached to a job type, one as template and another as AOI (shown in the screenshot below). The one attached as a template is not displayed from the workflow manager while the AOI is.
[ATTACH=CONFIG]26980[/ATTACH], [ATTACH=CONFIG]26981[/ATTACH], [ATTACH=CONFIG]26982[/ATTACH]
What might be the issue here?
Thank you
Best
Jamal
by Anonymous User
Not applicable
Hi Jamal,
The map you set up for the Job map on the Job Type is the map template that will be used when Launch Arcmap is executed in a workflow.
To set the map illustrated by the question mark you must be in the Workflow Manager Administrator and click Settings->Workflow Manager System Settings-> Map Views and select the map from the Job Result Map View.
Cheers,
Michael
by Anonymous User
Not applicable
Hi Jamal,
Cheers,
Michael
Many thanks Michael for the help,
I�??ll see if it works with me
Best
Jamal
